  • PRV Audio 12MB1500FT Forte Series 12" Midbass Speaker 8 Ohm
CLEARANCE PRV Audio 12MB1500FT Forte Series 12" Midbass Speaker 8 Ohm
PRV AudioPart # 294-2870
Model: 12MB1500FT
The PRV Audio 12MB1500FT is a high-performance 12-inch midbass loudspeaker engineered for professional audio applications requiring robust midbass reproduction. Part of PRV's Forte Series, it delivers exceptional linear response down to 75 Hz, making it ideal for 2-way cabinet systems that demand strong BL magnet force and impactful midbass punch.
  • High BL factor and Xmax for outstanding low-frequency output
  • Rated at 1500 watts RMS continuous program power
  • Sensitivity of 98.5 dB, capable of generating substantial output
  • 3.5" inside/outside CCAW voice coil wound on a fiberglass former for high-temperature performance
  • Heavy-duty spider with M-roll treated cloth surround, designed for high-excursion applications
  • Double silicon spider system ensures excellent control during large excursions
  • Strong ferrite magnetic structure with dual forced cooling system for efficient voice coil ventilation
PRV Audio 12MR2000 12" Pro Audio Midrange Woofer 8 Ohm
Price: $189.91Part # 294-2733
Lavoce WAF124.01 12" Woofer
Price: $289.00Part # 293-812
We'll send you an email when PRV Audio 12MB1500FT Forte Series 12" Midbass Speaker 8 Ohm is back in stock or available for preorder.
The PRV 12MB1500FT delivers a highly linear response, smoothly extending down to 75 Hz, making it an ideal choice for 2-way cabinet systems needing strong BL force and impactful midbass. It’s a powerful new addition to the Forte Series, focused on delivering higher power handling and reduced distortion in the mid to low midbass range.
  • Rated at 1500 watts RMS Continuous Program Power
  • 98.5 dB sensitivity, which makes it capable of generating a lot of output!
  • 3.5″ Inside/Out CCAW voice coil wound on fiberglass former for hi-temp performance, 8 Ohm
Supporting the cone is a heavy-duty spider with an M-roll treated cloth surround, specifically designed for high-excursion applications to handle short bursts of excessive power without sustaining damage. A double silicon spider system further enhances control during large excursions, allowing the driver to achieve up to 1.50 inches of peak-to-peak movement while maintaining performance and reliability.
A robust 25 mm ferrite magnetic structure ensures dynamic and precise performance, while the unique 3.5-inch inside/outside voice coil design delivers exceptionally high power handling of 1500 watts RMS. Enhanced by a dual forced cooling system, this design ensures highly efficient voice coil ventilation, minimizing power compression and maintaining consistent performance even during demanding audio applications.
  • Nominal Diameter: 12″ (305 mm)
  • Nominal impedance: 8 Ohm
  • Nominal Power Handling:* 750 Watts
  • Continuous Program Power (RMS):** 1500 Watts
  • Max Peak Power:*** 3000 Watts
  • Sensitivity 2.83V at 1m: 98.5 dB
  • Recommended Hi Pass Crossover: 90 Hz
    For Full Power Handling — 12db Per Octave Crossover
  • Frequency Response: 75 – 5,000 Hz
  • Voice Coil Diameter: 3.5″ (89 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 17.0 mm
  • Former Material: Glass Fiber
  • Magnetic Gap Depth: 10.0 mm
  • Frame Material: Die Cast Aluminum
  • Overall Diameter: 12.40” (315 mm)
  • Front Mount Baffle Cutout: 11.18” (284 mm)
  • Mounting Depth: 5.24”(133 mm)
  • Overall Depth: 5.87”(149 mm)
  • Net Weight: 16.32 Lbs (7.4 kg)
Explore the Forte Series
6MB550FT 6.5" Midbass Speaker 8 Ohm
6MB550FT-4 6.5" Midbass Speaker 4 Ohm
8MB700FT 8" Midbass Speaker 8 Ohm
8MB700FT-NDY 8" Neodymium Midbass Speaker 8 Ohm
8MB700FT-NDY-4 8" Neodymium Midbass Speaker 4 Ohm
10MB800FT 10" Midbass Speaker 8 Ohm
10MB1000FT 10" Midbass Speaker 8 Ohm
12MB1000FT 12" Midbass Speaker 8 Ohm
12MB1000FT-4 12" Midbass Speaker 4 Ohm
12MB1500FT 12" Midbass Speaker 8 Ohm
BrandPRV Audio
Model12MB1500FT
Part Number294-2870
UPC810075522761
Weight17.55
Nominal Diameter12"
Power Handling (RMS)1500 Watts
Power Handling (MAX)3000 Watts
Frequency Response75 to 5,000Hz
Sensitivity98.5dB 2.83V/1m
Voice Coil Diameter3.5"
Resonant Frequency (Fs)57.2Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.963mH
Mechanical Q (Qms)10.87
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)2.2ft³
BL Product (BL)17.27T·m
Diaphragm Mass Inc. Airload (Mms)59.32g
Surface Area of Cone (Sd)585cm²
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter12.40"
Baffle Cutout Diameter11.18"
Depth5.24"
