  • PRV Audio 6MB550FT Forte Series 6" Midbass Speaker 8 Ohm
PRV AudioPart # 294-2949
Model: 6MB550FT
The PRV Audio 6MB550FT is a 6" midbass loudspeaker from the Forte Series, engineered for high-output applications requiring punchy, low-distortion performance. It delivers robust sound suitable for various setups including stage monitors and touring systems. Its compact 3.33" mounting depth allows for versatile installation without demanding significant space.
  • 2" CCAW voice coil on fiberglass former for high power handling
  • 14 mm peak-to-peak excursion delivers deep, punchy bass
  • Cast aluminum frame provides structural integrity and reduces resonance
  • Frequency response of 85–7,500 Hz covers critical midrange frequencies
  • Vented pole piece dissipates heat to minimize power compression​
Your Price: $89.91
MSRP: $112.39
Save $22.48 (20%)
8 In Stock
We'll send you an email when PRV Audio 6MB550FT Forte Series 6" Midbass Speaker 8 Ohm is back in stock or available for preorder.
PRV Audio’s 6MB550FT 6.5″ Forte Series midbass is specifically designed to deliver greater Xmax and reduced distortion in mid to low midbass frequencies. With a Peak-to-Peak excursion of up to 14 mm (0.55″), this speaker packs a serious punch!
The tall 2″ voice coil provides excellent heat dissipation and strong motor force, enabling high sensitivity at high power levels with minimal distortion when used with a recommended High Pass filter of 95Hz at 12 dB per octave.
These refined design elements make the 6MB550FT a standout performer. With 94.5 dB efficiency and 275 watts of power handling, this midbass is ideal for use in stage monitors, auditoriums, touring rigs, and outdoor sound systems. Its smooth frequency response from 85 to 7,500 Hz makes it well-suited for both 2- and 3-way speaker designs.
  • Designed to handle low frequencies with high power output
  • Xmax 5.40 mm – 14 mm Peak-to-Peak excursion before damage
  • Large magnet enhances efficiency and control
  • High-power copper tinsel lead wire
  • Vented pole piece reduces power compression and boosts power handling
  • Durable cast aluminum frame built for demanding pro and car audio use
  • Natural paper cone with double-roll surround delivers smooth response
A sturdy cast aluminum frame with open spokes helps reduce reflections directed back into the cone. A large ferrite magnet, paired with precisely machined top and bottom plates, drives the voice coil with accuracy.
An extra forced vent in the backplate enhances cooling, allowing this driver to handle up to 550 watts RMS with ease.
This midbass is built to withstand years of demanding professional use!
 Its specially engineered spider minimizes distortion during high excursion, while the double roll surround maintains linear cone movement at high output. The copper tinsel lead wire supports high current transfer, combining performance-focused design and premium components to deliver outstanding clarity, detail, and dynamic sound.
Its CCAW voice coil features 14.8 mm of winding, delivering an impressive 5.40 mm Xmax and supporting up to 14 mm Peak-to-Peak excursion before damage—allowing the cone to move over 0.55″ for powerful punch.
The paper cone is crafted from a high-strength pulp blend engineered for optimal linearity in the midrange, and treated with a special coating that enhances damping characteristics, significantly improving the smoothness of the frequency response.
  • Nominal Diameter: 6″ (152 mm)
  • Nominal impedance: 8 Ohm
  • Nominal Power Handling:* 275Watts
  • Continuous Program Power (RMS):** 550 Watts
  • Max Peak Power:*** 1100 Watts
  • Sensitivity 2.83V at 1m: 94.5 dB
  • Recommended Hi Pass Crossover: 95 Hz
    For Full Power Handling — 12db Per Octave Crossover
  • Frequency Response: 85 – 7,500 Hz
  • Voice Coil Diameter: 2″ (51 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 14.8 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 8.0 mm
  • Frame Material: Die Cast Aluminum
  • Overall Diameter: 6.48″ (164.5 mm)
  • Front Mount Baffle Cutout: 5.59″ (142 mm)
  • Mounting Depth: 3.33″ (84.5 mm)
  • Overall Depth: 3.64″ (92.5 mm)
  • Net Weight: 5.95 Lbs (2.70 kg)
Explore the Forte Series
6MB550FT 6.5" Midbass Speaker 8 Ohm
6MB550FT-4 6.5" Midbass Speaker 4 Ohm
8MB700FT 8" Midbass Speaker 8 Ohm
8MB700FT-NDY 8" Neodymium Midbass Speaker 8 Ohm
8MB700FT-NDY-4 8" Neodymium Midbass Speaker 4 Ohm
10MB800FT 10" Midbass Speaker 8 Ohm
10MB1000FT 10" Midbass Speaker 8 Ohm
12MB1000FT 12" Midbass Speaker 8 Ohm
12MB1000FT-4 12" Midbass Speaker 4 Ohm
12MB1500FT 12" Midbass Speaker 8 Ohm
BrandPRV Audio
Model6MB550FT
Part Number294-2949
UPC602938022798
Weight6.3
Nominal Diameter6"
Power Handling (RMS)275 Watts
Power Handling (MAX)550 Watts
Frequency Response85 to 7,500Hz
Sensitivity94.5dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)84.9Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.42mH
Mechanical Q (Qms)3.83
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.34
Compliance Equivalent Volume (Vas)0.29ft³
Mechanical Compliance of Suspension (Cms)0.291mm/N
BL Product (BL)9.77T·m
Diaphragm Mass Inc. Airload (Mms)12.1g
Maximum Linear Excursion (Xmax)5.4mm
Surface Area of Cone (Sd)143cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter6.48"
Baffle Cutout Diameter5.59"
Depth3.64"
Sealed Volume0.2ft³
Sealed F3211.6Hz
Vented Volume0.4ft³
Vented F379Hz
