  • Klipsch R-8SW Reference Series 8" Down-Firing Powered Subwoofer
NEW Klipsch R-8SW Reference Series 8" Down-Firing Powered Subwoofer
KlipschPart # 247-2048
Model: R-8SW
The Klipsch R‑8SW is a compact powered subwoofer featuring an 8″ down‑firing IMG (Injection Molded Graphite) woofer and an efficient all‑digital amplifier. Designed for tight spaces, it delivers cinematic-level bass while offering flexible placement and versatile setup controls.
  • 8″ down-firing IMG woofer for deep, distortion-free low-frequency performance
  • All-digital amplifier for efficient, accurate power delivery
  • Compact cabinet fits discreetly in small rooms
  • Low-pass crossover and phase controls for seamless integration with main speakers
  • Line level inputs ensure compatibility with both legacy and modern receivers
  • Front-mounted LED power indicator shows active status at a glance
  • MDF enclosure with brushed polymer veneer finish combines durability with modern aesthetics
Polk Audio ES8SUB Signature Elite 8" Powered Subwoofer 100W
Price: $449.00Part # 243-637
See all items in Powered Subwoofers
NEW $399.99
We'll send you an email when Klipsch R-8SW Reference Series 8" Down-Firing Powered Subwoofer is back in stock or available for preorder.
Copper Down-Firing Woofer
Injection Molded Graphite (IMG) woofers are both exceptionally lightweight and extremely rigid, delivering outstanding low-frequency response with minimal cone breakup and distortion. The R-8SW’s down-firing design enhances low-frequency performance with minimal effort.
A Compact Design
Standing just 13.25" high and 11.75" deep, the R-8SW is the most compact Klipsch subwoofer, offering exceptional placement flexibility for any current or future room layout while delivering powerful, chest-thumping bass. Its sleek brushed polymer finish provides a modern look that blends seamlessly with your home décor.
Take Total Control
Low-pass crossover and phase controls let you seamlessly match the subwoofer's low-frequency output with other Klipsch speakers, while also tailoring the bass to your preference. Line/LFE inputs provide compatibility with both current and older receivers.
  • Frequency Response: 38Hz-120Hz +/-3dB
  • Maximum Acoustic Output: 108dB
  • Amplifier: All digital
  • Power Handling (Continuous/Peak): 50W/150W
  • Drive Components: 8” (20.3cm) high excursion, Injection Molded Graph, down-firing woofer
  • Enclosure Material: MDF
  • Enclosure Type: Bass Reflex via down-firing tube port
  • Inputs: Line level/LFE RCA jacks
  • Height: 13.25" (33.66 cm)
  • Width: 11.75" (29.85 cm)
  • Depth: 11.75" (298 mm)
  • Weight: 15 lbs. (6..8 kg)
  • Finish: Brushed Black Polymer Veneer
  • Features: Volume, Lowpass, Phase, Auto Power
  • Phase: Switchable 0-180°
  • Power Cord: Detachable
BrandKlipsch
ModelR-8SW
Part Number247-2048
UPC743878031249
Weight18.75
Woofer Diameter8"
