  • Klipsch R-800F Reference Series 8" Floorstanding Speaker
KlipschPart # 247-2041
Model: R-800F
The Klipsch R‑800F is a precision-engineered, high-efficiency floorstanding speaker designed to deliver expansive, detailed sound with dynamic clarity. It features advanced components and a refined cabinet build, offering a more immersive performance for both music and cinematic listening.
  • Dual 8″ spun-copper TCP woofers deliver smooth, accurate bass and midrange
  • 1″ aluminum LTS tweeter with 90° × 90° Tractrix® horn ensures clear, focused high frequencies
  • Rear-firing Tractrix® port boosts low-frequency output with minimal distortion
  • 98 dB sensitivity and 34–21 kHz frequency range for powerful, wide-spectrum sound
  • Durable MDF cabinet with scratch-resistant textured wood grain vinyl finish
  • Hidden fasteners and low-profile magnetic grilles create a modern, seamless appearance
  • Includes injection-molded stabilizer feet for secure placement and easy setup
Polk Audio ES55 Signature Elite Floor Standing Tower Speaker
Price: $449.00Part # 243-603
See all items in Floor-Standing & Tower Speakers
Your Price: $449.99
Save $175.00 (28%)
We'll send you an email when Klipsch R-800F Reference Series 8" Floorstanding Speaker is back in stock or available for preorder.
Order in the next 13 hr 18 min to ship today. Details
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive 1" LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the 8" TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
Rear Tractrix Port
The rear Tractrix port is precisely tuned to the cabinet and woofers, allowing for optimal airflow while minimizing distortion and turbulence, even at the lowest frequencies.
High-Quality Cabinet Design & Appearance
Hidden fasteners, an edge-to-edge horn, and low-profile magnetic grilles create a sleek, modern look. The MDF cabinets feature a scratch-resistant, textured wood grain finish that blends seamlessly with your home décor.
Refined Atmos Connections
Adding Dolby Atmos is simple with the discreet connections on the back of the speakers. These improved connections help keep wiring out of sight and secure them in place for neater cable management.
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
  • Frequency Response: 34Hz - 21kHz +/- 3dB
  • Sensitivity: 99 dB (In-Room)
  • Power Handling (Continuous/Peak): 150W/600W
  • Nominal Impedance: 8 ohms Compatible
  • Crossover Frequency: 1,400 Hz
  • High Frequency Driver: 1" Aluminum LTS tweeter mated to a 90° x 90° square Tractrix® Horn
  • Low Frequency Driver: Dual 8" spun-copper TCP woofers
  • Enclosure Material: MDF
  • Enclosure Type: Bass-Reflex via rear-firing Tractrix® ports
  • Inputs: Single Gold Plated Binding Posts
  • Height: 43" (1093 mm)
  • Width: 10.9" (277 mm)
  • Depth: 17.5" (443 mm)
  • Weight: 54 lbs. (24.5 kg)
  • Finish: Black Textured Wood Grain Vinyl
  • Included Accessories: Injection molded feet & screws
BrandKlipsch
ModelR-800F
Part Number247-2041
UPC743878046298
Weight67.25
ColorBlack
Configuration2-way
Input Rating8 ohm
Mounting StyleSet-Top
Woofer Diameter8"
Special FeaturesDolby Atmos
