  • Klipsch R-30C Reference Series 3.5" Center Channel Speaker
NEW Klipsch R-30C Reference Series 3.5" Center Channel Speaker
KlipschPart # 247-2046
Model: R-30C
The Klipsch R‑30C is a compact horn‑loaded center channel speaker engineered for precision dialog reproduction and full-bodied sound in home theater systems. Its advanced acoustic design ensures clarity, dynamic range, and an immersive listening experience vital for critical dialogue.
  • Quad 3.5″ spun‑copper TCP woofers for smooth mid‑bass performance and enhanced cone rigidity
  • 1″ aluminum LTS tweeter paired with a 90° × 90° Tractrix® horn for distortion‑minimized, projected high frequencies
  • Tapered array crossover enhances midrange coherence to preserve dialogue clarity
  • Bass‑reflex design with forward‑firing Tractrix® ports for clean, turbulence‑free low-end extension
  • Slim, low‑profile cabinet blends neatly with modern TVs and décor
  • Reinforced 3/4″ MDF enclosure with internal bracing lowers resonance for cleaner sound
  • 96 dB sensitivity and 78 Hz–21 kHz frequency range deliver expressive, full‑range audio with modest amplification
Polk Audio ES30 Signature Elite Center Channel Speaker
Price: $299.00Part # 243-604
See all items in Center Channel Speakers
NEW $524.99
We'll send you an email when Klipsch R-30C Reference Series 3.5" Center Channel Speaker is back in stock or available for preorder.
Expected back in stock any day
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive 1" LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the 3.5" TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
Hear Every Word
Tapered array crossovers enhance dispersion between the woofers and tweeters, delivering better midrange clarity. This technology is essential for hearing every detail and nuance in the dialogue of your favorite movies, music, and games.
Slim, High-Quality MDF Cabinet Design
With a sleek, space-saving design that pairs perfectly with modern flat-screen TVs, the next-generation Reference center channel speakers feature hidden fasteners and low-profile magnetic grilles. Their reinforced 3/4" MDF cabinets minimize vibration for greater sonic precision.
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference Redefined  series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
  • Frequency Response: 78Hz - 21kHz +/- 3dB
  • Sensitivity: 96 dB (In-Room)
  • Power Handling (Continuous/Peak): 100W/400W
  • Nominal Impedance: 8 ohms Compatible
  • Crossover Frequency: 1,650 Hz
  • High Frequency Driver: 1" Aluminum LTS tweeter mated to a 90° x 90° square Tractrix® Horn
  • Low Frequency Driver: Quad 3.5" spun-copper TCP woofers
  • Enclosure Material: MDF
  • Enclosure Type: Bass-Reflex via forward-firing Tractrix® ports
  • Inputs: Single Gold Plated Binding Posts
  • Height: 5" (126 mm)
  • Width: 26" (660 mm
  • Depth: 6.8" (173 mm)
  • Weight: 13 lbs (5.9 kg)
  • Finish: Black Textured Wood Grain Vinyl
BrandKlipsch
ModelR-30C
Part Number247-2046
UPC743878046342
Weight16.35
ColorBlack
Configuration2-way
Input Rating8 ohm
Mounting StyleSet-Top
Woofer Diameter3.5"
