  • Klipsch R-50C Reference Series 5.25" Center Channel Speaker
NEW Klipsch R-50C Reference Series 5.25" Center Channel Speaker
KlipschPart # 247-2045
Model: R-50C
The Klipsch R‑50C is a high-performance center channel speaker featuring horn-loaded design and premium drivers, engineered to deliver clear dialogue and immersive sound in home theater systems.
  • Dual 5.25″ spun‑copper TCP woofers for accurate mid‑bass articulation
  • 1″ aluminum LTS tweeter mated to a 90° × 90° Tractrix® horn for crisp, controlled highs
  • Sealed MDF cabinet with ¾″ reinforcement and internal bracing reduces resonance, enhancing sonic purity
  • 96 dB sensitivity and 90 Hz–21 kHz frequency range offer dynamic, full-range sound from modest amplification
  • Handles 100 W RMS (400 W peak) for reliable performance at higher listening levels
  • Sleek, modern appearance with hidden fasteners, edge-to-edge horn, and magnetic grille for seamless integration into décor
  • Compact footprint makes it easy to fit under TVs or in tight setups
Polk Audio ES30 Signature Elite Center Channel Speaker
Price: $299.00Part # 243-604
See all items in Center Channel Speakers
NEW $269.99
MSRP: $374.99
Save $105.00 (28%)
We'll send you an email when Klipsch R-50C Reference Series 5.25" Center Channel Speaker is back in stock or available for preorder.
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive 1" LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the 5.25" TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
Hear Every Word
Tapered array crossovers enhance dispersion between the woofers and tweeters, delivering better midrange clarity. This technology is essential for hearing every detail and nuance in the dialogue of your favorite movies, music, and games.
Slim, High-Quality MDF Cabinet Design
With a sleek, space-saving design that pairs perfectly with modern flat-screen TVs, the next-generation Reference center channel speakers feature hidden fasteners and low-profile magnetic grilles. Their reinforced 3/4" MDF cabinets minimize vibration for greater sonic precision.
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference Redefined series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
  • Frequency Response: 90Hz - 21kHz +/- 3dB
  • Sensitivity: 96 dB (In-Room)
  • Power Handling (Continuous/Peak): 100W/400W
  • Nominal Impedance: 8 ohms Compatible
  • Crossover Frequency: 1,650 Hz
  • High Frequency Driver: 1" Aluminum LTS tweeter mated to a 90° x 90° square Tractrix® Horn
  • Low Frequency Driver: Dual 5.25" spun-copper TCP woofers
  • Enclosure Material: MDF
  • Enclosure Type: Sealed
  • Inputs: Single Gold Plated Binding Posts
  • Height: 7" (178 mm)
  • Width: 18.75" (476 mm)
  • Depth: 8.2" (208 mm)
  • Weight: 14 lbs. (6.3 kg)
  • Finish: Black Textured Wood Grain Vinyl
BrandKlipsch
ModelR-50C
Part Number247-2045
UPC743878046359
Weight16.6
ColorBlack
Input Rating8
Woofer Diameter5.25"
