  • Klipsch R-40M Reference Series 4" Bookshelf Speaker Pair
KlipschPart # 247-2044
Model: R-40M
The Klipsch R-40M is a compact yet dynamic bookshelf speaker engineered to deliver clear, spacious sound with punchy mid-bass and detailed highs. Its Tractrix® horn loading and spun-copper woofer give it performance well beyond its modest size.
  • 4" spun-copper TCP woofer for clear midrange and punchy bass
  • 1" LTS aluminum tweeter with Tractrix® horn for crisp, detailed highs
  • Rear-firing Tractrix® port for efficient, low-distortion bass output
  • Compact, lightweight design fits easily into smaller spaces
  • High-quality MDF cabinet with scratch-resistant textured wood grain vinyl finish
  • 91 dB sensitivity and 71 Hz–21 kHz range provide full-spectrum sound with modest power needs
  • Sleek appearance and removable magnetic grille offers a streamlined look and easy cleaning
See all items in Bookshelf Speakers
Your Price: $199.99
Save $100.00 (33%)
We'll send you an email when Klipsch R-40M Reference Series 4" Bookshelf Speaker Pair is back in stock or available for preorder.
Order in the next 0 hr 41 min to ship today. Details
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive 1" LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the 4" TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
High-Quality Cabinet Design & Appearance
Hidden fasteners, an edge-to-edge horn, and low-profile magnetic grilles create a sleek, modern look. The MDF cabinets feature a scratch-resistant, textured wood grain finish that blends seamlessly with your home décor.
Need a Lift?
Klipsch has designed their speakers to work best on speaker stands. Bring your bookshelf speakers up to your level and hear your music and movies the way they were meant to be heard.
Shop Speaker Stands
Refined Atmos Connections
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference Redefined  series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
  • Frequency Response: 71Hz - 21kHz +/- 3dB
  • Sensitivity: 91 dB (In-Room)
  • Power Handling (Continuous/Peak): 50W/200W
  • Nominal Impedance: 8 ohms Compatible
  • Crossover Frequency: 1,770 Hz
  • High Frequency Driver: 1" Aluminum LTS tweeter mated to a 90° x 90° square Tractrix® Horn
  • Low Frequency Driver: Single 4" spun-copper TCP woofer
  • Enclosure Material: MDF
  • Enclosure Type: Bass-Reflex via rear-firing Tractrix® ports
  • Inputs: Single Gold Plated Binding Posts
  • Height: 11.7" (298 mm)
  • Width: 5.8" (146 mm)
  • Depth: 8.5" (216 mm)
  • Weight: 7 lbs. (3.2 kg)
  • Finish: Black Textured Wood Grain Vinyl
BrandKlipsch
ModelR-40M
Part Number247-2044
UPC743878046335
Unit of MeasurePairs
Weight17.7
ColorBlack
Configuration2-way
Input Rating8 ohm
Mounting StyleSet-Top
Woofer Diameter4"
