  • Klipsch R-50M Reference Series 5.25" Bookshelf Speaker Pair
KlipschPart # 247-2043
Model: R-50M
The Klipsch R-50M is a compact, horn-loaded bookshelf speaker offering rich, dynamic sound in a stylish, space-saving design. Engineered with premium components and refined cabinetry, it delivers clarity and precision across music and home theater setups.
  • Linear Travel Suspension to reduce distortion and enhance overall performance
  • Single 5.25″ spun-copper TCP woofer with ribbing for smooth, accurate bass
  • 1″ aluminum LTS tweeter mated to a 90° × 90° Tractrix® horn for crisp, clear highs
  • Bass-reflex design with rear-firing port enhances low-end extension
  • 92 dB sensitivity and 58 Hz–21 kHz frequency response offer wide, powerful coverage
  • MDF cabinet with scratch-resistant wood grain vinyl and hidden fasteners for refined aesthetics
  • Hidden fasteners and magnetic grille deliver a clean, modern aesthetic
See all items in Bookshelf Speakers
Your Price: $299.99
Save $125.00 (29%)
We'll send you an email when Klipsch R-50M Reference Series 5.25" Bookshelf Speaker Pair is back in stock or available for preorder.
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive 1" LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the 5.25" TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
High-Quality Cabinet Design & Appearance
Hidden fasteners, an edge-to-edge horn, and low-profile magnetic grilles create a sleek, modern look. The MDF cabinets feature a scratch-resistant, textured wood grain finish that blends seamlessly with your home décor.
Need a Lift?
Klipsch has designed their speakers to work best on 28" speaker stands. Bring your bookshelf speakers up to your level and hear your music and movies the way they were meant to be heard.
Shop Speaker Stands
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference Redefined series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
  • Frequency Response: 58Hz - 21kHz +/- 3dB
  • Sensitivity: 92 dB (In-Room)
  • Power Handling (Continuous/Peak): 75W/300W
  • Nominal Impedance: 8 ohms Compatible
  • Crossover Frequency: 1,560 Hz
  • High Frequency Driver: 1" Aluminum LTS tweeter mated to a 90° x 90° square Tractrix® Horn
  • Low Frequency Driver: Single 5.25" spun-copper TCP woofer
  • Enclosure Material: MDF
  • Enclosure Type: Bass-Reflex via rear-firing Tractrix® ports
  • Inputs: Single Gold Plated Binding Posts
  • Height: 13.9" (354 mm)
  • Width: 7" (178 mm)
  • Depth: 9" (229 mm)
  • Weight: 11 lbs. (5 kg)
  • Finish: Black Textured Wood Grain Vinyl
BrandKlipsch
ModelR-50M
Part Number247-2043
UPC743878046328
Unit of MeasurePairs
Weight25.15
ColorBlack
Configuration2-way
Input Rating8 ohm
Mounting StyleSet-Top
Woofer Diameter5.25"
