  • Klipsch R-101SW Reference Series 10" Powered Subwoofer
KlipschPart # 247-2049
Model: R-101SW
The Klipsch R‑101SW is a compact, front-firing powered subwoofer featuring a 10″ spun-copper TCP woofer and a high-efficiency all-digital amplifier. Engineered for tight-space placement, it delivers deep, dynamic bass with advanced control for seamless system integration.
  • 10″ spun‑copper Thermoformed Crystalline Polymer (TCP) woofer for clear, distortion‑free low frequencies
  • Built-in all‑digital amplifier combines power and precision
  • Wide 29.5 Hz–120 Hz frequency response for deep bass extension
  • Maximum acoustic output of 115 dB delivers impactful, room-filling performance
  • Low-pass crossover and phase control for tailored integration with main speakers
  • Sealed MDF cabinet with reinforced bracing and scratch-resistant vinyl for durability and clarity
  • Low-profile grille and front-mounted LED offer elegant styling and functionality
Polk Audio ES10SUB Signature Elite 10" Powered Subwoofer 200W
Price: $699.00Part # 243-638
See all items in Powered Subwoofers
Your Price: $549.99
We'll send you an email when Klipsch R-101SW Reference Series 10" Powered Subwoofer is back in stock or available for preorder.
New Tech | Cleaner Bass
The updated spun-copper thermoformed crystalline polymer woofers in the latest Reference subwoofers are extremely lightweight yet highly rigid, delivering deep low-frequency response with minimal cone breakup and distortion-free performance.
All-Digital Amplifier
The integrated all-digital amplifier provides robust power with exceptional efficiency and precise, true-to-source audio reproduction, delivering best-in-class output, detail, and performance.
Front-Firing Driver
The high-performance 10" driver provides deep bass and flexible room placement.
Highly Durable & Versatile Cabinet Design
Reference Subwoofers combine a refined appearance with exceptional durability, allowing them to blend seamlessly into any décor. They feature a scratch-resistant finish, reinforced 3/4" MDF construction, an all-new bracing design to minimize vibration, a front-mounted LED power indicator, and a low-profile grille for acoustic transparency.
Low Pass Crossover & Phase Control
Allows the subwoofer’s low-frequency output to integrate smoothly with other Klipsch speakers while letting you fine-tune the bass to your preference.
Line/LFE Inputs
Reference subwoofers work seamlessly with any home theater receiver, regardless of brand or model.
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference series and get ready for an unforgettable listening experience.
  • Frequency Response: 29.5Hz-120Hz
  • Maximum Acoustic Output: 115dB
  • Amplifier: All digital
  • Power Handling (Continuous/Peak): 150W/300W
  • Amplifier Features: Volume, Low-pass, 0/180 phase, Auto Power On
  • Drive Components: 10" high excursion spun-copper TCP woofer
  • Enclosure Material: MDF
  • Enclosure Type: Bass Reflex via rear-firing port
  • Inputs: Line level/LFE RCA jacks
  • Height: 14.6" (370 mm)
  • Width: 14.0" (356 mm)
  • Depth: 19.7" (500 mm)
  • Weight: 31 lbs. (13.9 kg)
  • Finish: Black Textured Wood Grain Vinyl
BrandKlipsch
ModelR-101SW
Part Number247-2049
UPC743878046755
Weight37.35
Woofer Diameter10"
