  • Dayton Audio CS800 8" 150W Powered Subwoofer Black
Dayton AudioPart # 300-601
Model: CS800-Black
Renowned for setting new standards in audio performance, Dayton Audio takes things to the next level with the all-new Classic Collection powered subwoofers. Available in 8", 10", and 12" sizes and two finishes, these subwoofers feature rugged, tank-like construction and a striking design that perfectly matches the rest of the Dayton Audio Classic Collection family of speakers. Engineered to deliver deep, powerful bass, they consistently exceed expectations—making them true overachievers in both form and function.
  • Newly designed mineral-reinforced paper cone driver creates incredible low-frequency performance
  • Built-in efficient Class-D amplifier provides 150 watts of true power for room shaking bass
  • Low distortion for clean, precise bass that brings movies and music to life
  • Rigid, braced cabinets ensure tight, controlled bass for reliable performance over time
  • Easy to add to any audio system with simple setup, auto-on and flexible input options
  • Designed in Dayton, Ohio and backed by a 5-year warranty
Klipsch R-8SW Reference Series 8" Down-Firing Powered Subwoofer
Price: $399.99Part # 247-2048
See all items in Powered Subwoofers
Your Price: $159.98
Save $40.01 (20%)
We'll send you an email when Dayton Audio CS800 8" 150W Powered Subwoofer Black is back in stock or available for preorder.
Estimated back in stock 10/23/2026
Uncompromised High-end Performance
Dayton set out to build a subwoofer that enhances every detail of your favorite music, movies, and games, without coloring the sound or adding unnecessary noise. Their design ensures that all frequencies are free from unwanted peaks or valleys, allowing your audio to shine.
Real World Power
Built to deliver real-world power, the Classic Collection Subwoofers fill your room with clean, controlled bass without distortion or unnecessary hype. Designed by engineers with over 48 years of combined audio experience, the Classic Collection subwoofers reflect the commitment to honest engineering and performance you can trust from Dayton Audio. Each model is powered by a high-efficiency amplifier tuned for smooth response and reliable output rather than inflated wattage claims. The driver and amplifier work together to provide effortless low-end extension that feels both powerful and natural.
Sounds as Good as it Looks
As part of the larger Classic Collection of home audio speakers, these powered subwoofers offer a design that fits seamlessly into any décor, whether modern or traditional. They are available in black wood grain with a black grille or light wood grain with a gray grille to suit your style. The Classic Collection subwoofers come with rubber feet installed with M6 threaded inserts but can be easily upgraded by swapping them for Dayton Audio speaker spikes (sold separately).
Simple Connections and Easy Operation
Our Classic Collection subwoofers offer multiple connection options to suit any system, including an RCA input for a simple, no-nonsense connection from the RCA outputs of most amplifiers, an LFE input for seamless home theater integration with a surround sound receiver, and high-level speaker inputs for use with amplifiers that lack a dedicated subwoofer output. With the high-level inputs, you can easily run speaker wires from the amp to the subwoofer and then out to your speakers to accommodate any amplifier.
Auto-on functionality puts the subwoofer into standby when not in use and powers it on automatically when a signal is detected. The crossover knob and phase switch help blend seamlessly with your main speakers, while the volume control lets you fine-tune the bass so it’s just right for your room and your listening style.
Built to a Higher Standard
Every part of this subwoofer was conceived and designed in Dayton, Ohio. From the cabinet to the driver and amplifier, each component was carefully examined, tested, and refined until Dayton Audio's engineers achieved a design they could be proud of. The driver was engineered to reduce distortion while delivering maximum output. The cabinet is built using 18mm MDF throughout and features rigid internal bracing to better control low-frequency response and provide clean, accurate bass.
*Note - For visual purposes only. Disassembling your subwoofer will void the warranty.*
Dayton Audio's goal is to deliver a standard of quality and value that exceeds expectations. We back all products with a 5-year warranty because we believe in them, and trust you will too. Decades of experience in designing speaker drivers went into the development of the Classic Collection subwoofers, resulting in a product we are proud of: One that delivers outstanding performance and enjoyment to our customers.
CS800 Specifications
EnclosurePorted
Woofer8" Mineral Filled Paper Cone
Amplifier Output150 Watts (RMS)
Frequency Response35 - 200 Hz
Line Level InputsStereo RCA, LFE
Speaker Level InputsSpring Terminals with Passthrough
Lowpass Filter40 - 160 Hz
Phase Control0º / 180º
Auto OnYes
Dimensions
11.5 x 14 x 12.37 in. (292 x 355 x 314 mm)
Weight
22.8 lbs. (10.34 kg)
What's In The Box
  • 1 x CS800 Subwoofer
  • 1 x Speaker Grille
  • 4 x Rubber Feet
  • 1 x 6 ft. Power Cable
  • 1 x User Manual
ModelCS800-Black
Part Number300-601
UPC848791011375
Weight28.75
Woofer Diameter8"
