PRV Audio 12MR2000X v2 X Series 12" Midrange Speaker 8 Ohm
PRV's X Series is committed to offering extreme midrange performance and high power capability in both the pro and competitive car audio worlds. The 12MR2000X v2 is a 12″ midrange loudspeaker engineered for high-efficiency and extreme output capability. Designed for the largest SPL systems, it delivers detailed vocal reproduction and high-fidelity response, making it ideal for professional audio applications.
- Handles up to 2,000 Watts RMS with 100 dB sensitivity for exceptional output capability
- 4″ diameter voice coil wound on a glass fiber former ensures reliable high-temperature performance
- 6.60 mm Xmax allows excellent control to deliver high-impact midbass
- Extensive venting keeps the voice coil cool, improving reliability during intense operation
- Composite cone built with non-pressed paper reduces break-up for smooth sound
- Double roll suspension design allows for strong response even at high excursion
- Sturdy, reinforced cast-aluminum frame provides durability in demanding applications.
We'll send you an email when PRV Audio 12MR2000X v2 X Series 12" Midrange Speaker 8 Ohm is back in stock or available for preorder.
