PRV Audio 12MR1200X X Series 12" Midrange Speaker 8 Ohm
PRV's X Series is committed to offering extreme midrange performance and high power capability in both the pro and competitive car audio worlds. The 12MR1200X is a high-performance 12″ midrange loudspeaker engineered for extreme sound pressure level (SPL) applications. It offers exceptional vocal clarity and dynamic range, making it ideal for pro audio systems and competitive car setups.
- Designed for extreme SPL with output levels exceeding 130 dB
- 3" inside/outside voice coil delivers superior heat resistance and stability
- Ventilated gap reduces power compression for consistent high-power performance
- Lightweight cone enhances midrange clarity
- Performs excellently in compact enclosures and custom door installations.
- Aluminum die-cast frame increases strength and aids thermal dissipation
- Precision-tuned for detailed vocal reproduction in the 260–3,800 Hz range
We'll send you an email when PRV Audio 12MR1200X X Series 12" Midrange Speaker 8 Ohm is back in stock or available for preorder.
