  • Dayton Audio DMPC-90 90uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-446
Model: DMPC-90
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC rating
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 48 mm x 75 mm
Your Price: $28.19
Save $8.80 (24%)
153 In Stock
We'll send you an email when Dayton Audio DMPC-90 90uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers. Large values are great for 3-way speaker designs.
• Value: 90.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 48 mm Dia. x 75 mm L.
ModelDMPC-90
Part Number027-446
UPC844632016349
Weight0.3
Capacitance90 uF
Tolerance5%
Voltage Rating250V
