  • Dayton Audio DMPC-0.33 0.33uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-404
Model: DMPC-0.33
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 8 mm x 18 mm
Your Price: $0.59
Save $0.40 (40%)
1011 In Stock
We'll send you an email when Dayton Audio DMPC-0.33 0.33uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Order in the next 4 hr 4 min to ship today. Details
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 0.33 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 8 mm Dia. x 18 mm L.
ModelDMPC-0.33
Part Number027-404
UPC844632013683
Weight0.005
Capacitance0.33 uF
Tolerance5%
Voltage Rating250V
