  • Dayton Audio DMPC-40 40uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-442
Model: DMPC-40
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 37 mm x 60 mm
Jantzen Audio 39uF 400V Cross Cap Crossover Capacitor
Price: $19.58Part # 027-946
Solen 39uF 400V Polypropylene Capacitor
Price: $20.98Part # 027-596
Your Price: $9.89
Save $3.10 (24%)
We'll send you an email when Dayton Audio DMPC-40 40uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Estimated back in stock 8/28/2026
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 40.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 37 mm Dia. x 60 mm L.
ModelDMPC-40
Part Number027-442
UPC844632013867
Weight0.12
Capacitance40 uF
Tolerance5%
Voltage Rating250V
