  • Dayton Audio DMPC-27 27uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-439
Model: DMPC-27
Make the Dayton Audio line of metalized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 30 mm x 60 mm
Your Price: $6.99
MSRP: $9.99
Save $3.00 (30%)
134 In Stock
We'll send you an email when Dayton Audio DMPC-27 27uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Make the Dayton Audio line of metalized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 27.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 30 mm Dia. x 60 mm L.
ModelDMPC-27
Part Number027-439
UPC844632077371
Weight0.11
Capacitance27 uF
Tolerance5%
Voltage Rating250V
