  • Dayton Audio DMPC-2.7 2.7uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-416
Model: DMPC-2.7
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 14 mm x 31 mm
Dayton Audio PMPC-2.7 2.7uF 250V Precision Audio Capacitor
Price: $3.49Part # 027-218
Your Price: $1.09
Save $0.90 (45%)
We'll send you an email when Dayton Audio DMPC-2.7 2.7uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Estimated back in stock 11/13/2026
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 2.7 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 14 mm Dia. x 31 mm L.
ModelDMPC-2.7
Part Number027-416
UPC844632013744
Weight0.013
Capacitance2.7 uF
Tolerance5%
Voltage Rating250V
