  • Dayton Audio DMPC-4.3 4.3uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-419
Model: DMPC-4.3
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Dimensions: 18.5 mm x 31 mm
Your Price: $1.59
Save $1.40 (47%)
608 In Stock
We'll send you an email when Dayton Audio DMPC-4.3 4.3uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Order in the next 15 hr 58 min to ship today. Details
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 4.3 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 18.5 mm Dia. x 31 mm L.
ModelDMPC-4.3
Part Number027-419
UPC844632014611
Weight0.005
Capacitance4.3 uF
Tolerance5%
Voltage Rating250V
