  • Dayton Audio DMPC-30 30uF 250V Polypropylene Capacitor
Dayton AudioPart # 027-440
Model: DMPC-30
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 31 mm x 60 mm
Your Price: $7.69
MSRP: $9.99
Save $2.30 (23%)
163 In Stock
We'll send you an email when Dayton Audio DMPC-30 30uF 250V Polypropylene Capacitor is back in stock or available for preorder.
Order in the next 8 hr 0 min to ship today. Details
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 30.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 31 mm Dia. x 60 mm L.
ModelDMPC-30
Part Number027-440
UPC844632013850
Weight0.12
Capacitance30 uF
Tolerance5%
Voltage Rating250V
