  • PRV Audio MT8MR400CF-NDY-4 SLIM Moto Series 8" Carbon Fiber Neodymium Midrange Loudspeaker 4 Ohm
NEW PRV Audio MT8MR400CF-NDY-4 SLIM Moto Series 8" Carbon Fiber Neodymium Midrange Loudspeaker 4 Ohm
PRV AudioPart # 267-8032
Model: MT8MR400CF-NDY-4 SLIM
Introducing the PRV MOTO Series, an innovative line of high-performance speakers engineered for the rigors of motorsports. Built with only the best components that are made to weather the great outdoors, the MOTO Series is here to upgrade your motorcycle, boat, ATV, side-by-side, and more. Bring the MOTO quality to your midrange needs with the MT8MR400CF-NDY-4 SLIM, and don't sweat the rain or the mounting depth.
  • Water-resistant to endure the rain or the tide
  • A slim 2.5" mounting depth allows this speaker to fit almost anywhere
  • Crisp vocal reproduction that PRV Audio is renowned for
  • The carbon fiber cone is light yet strong, keeping your sound under control
  • The amazing off-axis and transient response makes for a smooth transition to a super tweeter
  • A wide frequency range of 120-12K Hz gives you the option of skipping the super tweeter entirely
  • Grill and screws included
NEW $139.91
MSRP: $174.89
Save $34.98 (20%)
We'll send you an email when PRV Audio MT8MR400CF-NDY-4 SLIM Moto Series 8" Carbon Fiber Neodymium Midrange Loudspeaker 4 Ohm is back in stock or available for preorder.
The PRV MOTO Series
PRV Audio is excited to introduce their MOTO Series, a high-performance line designed specifically for motorsports installations. This series features the latest innovative materials and components, engineered to withstand weather conditions while delivering top-tier sound quality. These components set a new standard for high output in outdoor applications, making them perfect for upgrading the sound system in your motorcycle, boat, side-by-side, or ATV.
  • Water-resistant speaker delivering an authentic pro audio midrange performance
  • Carbon fiber cone with coated suspension designed for outdoor durability
  • Full-range sound with low inductance technology, extending frequency response up to 12,000 Hz
  • High-output speaker ideal for ATVs, Slingshots, and motorcycles, fitting most stock mounting locations
  • Engineered for compact spaces with a slim 2.5" mounting depth, without compromising quality or performance
  • Grill and screws are included
In addition to its sleek appearance, this carbon fiber cone is remarkably lightweight, highly rigid, and offers excellent damping to manage narrow peaks.
Despite its compact design, PRV's technical team achieved precise vocal reproduction, delivering the renowned PRV Audio pro sound.
A specially treated surround and flat spider support the cone, maintaining linear movement through its full excursion with minimal restriction, enhancing dynamics and transients.
This midrange includes several premium components, such as stitched lead wires that connect the voice coil to the terminals through a single-layer spider suspension. It’s powered by a copper-clad aluminum voice coil for high efficiency and outstanding power handling, combined with a robust neodymium motor that immerses the voice coil in a powerful magnetic field.
This water-resistant speaker delivers excellent off-axis and transient response, ensuring controlled sound and a smooth transition to a super tweeter.
Designed for loud and clear vocal performance in tight spaces, PRV Audio’s MT8MR400CF-NDY-4 SLIM midrange boasts a sensitivity of 95 dB (2.00V/1m) and weighs just 1.63 pounds, with a 4-ohm impedance.
The MOTO Series is crafted to provide exceptional pro audio performance for motorsports applications.
This speaker is engineered for reliable, consistent high output across a broad frequency range of 120 to 12,000 Hz, potentially eliminating the need for a super tweeter in your system.
MT8MR400CF-NDY-4 SLIM Specifications
Explore the PRV MOTO Series
MT6MR400CF-NDY-4 SLIM 6.5" Carbon Fiber Neodymium Midrange Loudspeaker 4 Ohm
MT8MR400CF-NDY-4 SLIM 8" Carbon Fiber Neodymium Midrange Loudspeaker 4 Ohm
MT6MR600CF-NDY-2 6.5" Neodymium Midrange Loudspeaker 2 Ohm
MT6CX580-NDY-4 6.5" Coaxial Loudspeaker
MT8MR600-NDY-4 8" Neodymium Midrange Loudspeaker 4 Ohm
MT10W1200-NDY-4 10" Pro Low Frequency Woofer 4 Ohm
MT8SW800 D4 8" Shallow Subwoofer DVC 4x4 Ohm
MT10SW1000 D4 10" Shallow Subwoofer DVC 4x4 Ohm
MT2.2TWB-4 2.25" Short Horn Black Tweeter 4 Ohm
MT2.2TWC-4 2.25" Short Horn Chrome Tweeter 4 Ohm
MT2.7TWB-4 2.75" Short Horn Chrome Tweeter 4 Ohm
BrandPRV Audio
ModelMT8MR400CF-NDY-4 SLIM
Part Number267-8032
UPC810075522426
Weight2.87
Nominal Diameter8"
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response110 To 13,500Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)111.3Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.104mH
Mechanical Q (Qms)9.07
Electromagnetic Q (Qes)0.88
Total Q (Qts)0.8
Compliance Equivalent Volume (Vas)0.33ft³
Mechanical Compliance of Suspension (Cms)0.131mm/N
BL Product (BL)6.49T·m
Diaphragm Mass Inc. Airload (Mms)15.6g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)227cm²
Cone MaterialCarbon Fiber
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Overall Outside Diameter8.23"
Baffle Cutout Diameter7.11"
Depth3.68"
