NEW Dayton Audio PCS175-4 6-1/2" Poly Cone Woofer 4 Ohm
- Durable poly cone and rubber surround for smooth response and long service life
- 4-layer voice coil on aluminum former for improved thermal handling during demanding playback
- Large diameter flat spider improves cone control and supports consistent excursion
- Low-profile stamped steel frame ideal for surface-mounted speaker systems
- Efficient 89 dB sensitivity for strong output with modest amplifier power
We'll send you an email when Dayton Audio PCS175-4 6-1/2" Poly Cone Woofer 4 Ohm is back in stock or available for preorder.
