NEW Dayton Audio PCS8-4 8" Paper Cone Subwoofer Driver 4 Ohm
- Grey poly-coated paper cone delivers strong bass with a clean, modern appearance
- Over 90 dB sensitivity helps produce higher output from modest amplifier power
- 43 Hz Fs and 5 mm Xmax support solid low-frequency performance in medium sized builds
- Extensive motor venting helps reduce heat buildup during demanding playback
- Shallow flange stamped steel frame provides rigid support and a finished look
- 150 watts RMS power handling for reliable use in powered and passive subwoofer projects
- Drop-in replacement woofer for the Dayton Audio CS800 powered subwoofer
We'll send you an email when Dayton Audio PCS8-4 8" Paper Cone Subwoofer Driver 4 Ohm is back in stock or available for preorder.
