NEW Dayton Audio PCS12-4 12" Paper Cone Subwoofer Driver 4 Ohm
- 12" paper cone delivers powerful low-frequency output with strong impact
- 30 Hz Fs supports deep bass extension in properly designed enclosures
- Over 90 dB sensitivity helps produce high output from modest amplifier power
- 7 mm Xmax and large-roll rubber surround support controlled excursion
- Grey poly-coated cone and inverted dust cap provide a clean, modern look
- Fully vented motor system helps improve heat dissipation during playback
- 180 watts RMS power handling gives DIY builds ample headroom
We'll send you an email when Dayton Audio PCS12-4 12" Paper Cone Subwoofer Driver 4 Ohm is back in stock or available for preorder.
