  • Dayton Audio PCS115-8 4" Poly Cone Woofer 8 Ohm
Dayton AudioPart # 295-662
Model: PCS115-8
The Dayton Audio PCS115-8 4" 8-ohm poly cone woofer is designed for smooth midbass and midrange performance with reliable operation in compact speaker systems. Its grey polypropylene cone and inverted dustcap give the driver a distinctive modern appearance while delivering the durability and controlled response expected from Dayton Audio drivers.
  • Poly cone and rubber surround combination for controlled response and dependable performance
  • Low-profile stamped steel frame simplifies installation in compact speaker designs
  • Aluminum former with 2-layer voice coil for improved thermal stability
  • Under-spider venting reduces compression and promotes cooler operation
  • Large diameter flat spider improves stability and helps maintain linear excursion
Dayton Audio PCS115-4 4" Poly Cone Woofer 4 Ohm
Price: $12.98Part # 295-660
See all items in Woofers
Your Price: $12.98
Save $7.01 (35%)
We'll send you an email when Dayton Audio PCS115-8 4" Poly Cone Woofer 8 Ohm is back in stock or available for preorder.
Engineered for small speaker systems and versatile audio designs, the PCS115-8 uses a polypropylene cone that provides excellent damping and environmental stability. The grey cone and inverted dustcap add a modern visual touch, making the driver suitable for projects where appearance matters just as much as performance. A rubber surround supports controlled excursion and helps maintain long-term reliability in demanding applications. The PCS115-8 is a direct replacement woofer for the Dayton Audio C40 center channel speaker, allowing quick and easy repair while maintaining the speaker’s original sound.
A large diameter flat spider keeps the moving assembly stable and centered, helping the driver maintain smooth, linear motion. The motor assembly features a ferrite magnet paired with a two-layer voice coil wound on an aluminum former, improving heat dissipation and maintaining consistent performance during extended listening sessions. Under-spider venting improves airflow around the voice coil, reducing heat buildup and compression.
With usable response from 60 Hz to 6 kHz and sensitivity of 82.4 dB, the PCS115-8 is well suited for compact two-way speakers, multi-driver systems, and custom audio designs where a small woofer is required.
The PCS115-8 is a direct replacement woofer for the Dayton Audio C40 center channel speaker, providing an easy replacement driver for repairing or restoring C40 speaker systems.
Compatibility:
ModelPCS115-8
Part Number295-662
UPC848791012136
Weight1.25
Nominal Diameter4"
Bolt Circle Diameter4.3
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Frequency Response60 - 6,000Hz
Sensitivity82.5dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)87Hz
DC Resistance (Re)6.8Ω
Voice Coil Inductance (Le)0.55mH
Mechanical Q (Qms)2.69
Electromagnetic Q (Qes)1.22
Total Q (Qts)0.84
Compliance Equivalent Volume (Vas)0.0625ft³
Mechanical Compliance of Suspension (Cms)0.48mm/N
BL Product (BL)4.6T·m
Diaphragm Mass Inc. Airload (Mms)7g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)51.5cm²
Cone MaterialPoly
Voice Coil FormerAluminum
Overall Outside Diameter4.5"
Baffle Cutout Diameter3.7"
Depth2.25"
Sealed Volume0.18ft³
Sealed F387Hz
Vented Volume0.27ft³
Vented F340Hz
