Dayton Audio PCS115-4 4" Poly Cone Woofer 4 Ohm
- Smooth sounding poly cone with rubber surround for balanced response and long-term durability
- Low-profile frame design allows easy installation in surface-mounted installations
- Aluminum voice coil former with 2-layer coil for improved heat dissipation and reliability
- Under-spider venting helps reduce heat buildup and improves power handling
- Large diameter flat spider for improved cone stability and consistent linear motion
We'll send you an email when Dayton Audio PCS115-4 4" Poly Cone Woofer 4 Ohm is back in stock or available for preorder.
