  • PRV Audio MDX2500.1 2 Ohm MDX Series 1-Channel Mini Amplifier 2600W
NEW PRV Audio MDX2500.1 2 Ohm MDX Series 1-Channel Mini Amplifier 2600W
PRV AudioPart # 267-8075
Model: MDX2500.1 2 Ohm
Perfect for high-performance systems with limited space, the MDX Series incorporates exclusive patented technologies to deliver high-definition sound quality in a small yet reliable package. Built with motorsports in mind, this tiny yet powerful amplifier is an excellent choice for your motorcycle, ATV, or slingshot.
  • Small but mighty to deliver results without taking up space
  • 84% average efficiency delivers on output without straining your electrical system
  • Built in heatsink and cooling fan to keep the amp cool under the most demanding conditions
  • High level input to make connecting to a factory radio a breeze
  • A frequency response from 10-25,000Hz will let this amp handle any job you can give it
  • Engineered to endure vibration and still deliver a peak performance
  • An excellent choice for motorcycles, ATVs, and slingshots
PRV Audio QS2000 2 Ohm QS Series 1-Channel Full-Range Amplifier 2000W
Price: $179.91Part # 294-3558
See all items in Car Amplifiers
NEW $169.91
MSRP: $212.39
Save $42.48 (20%)
We'll send you an email when PRV Audio MDX2500.1 2 Ohm MDX Series 1-Channel Mini Amplifier 2600W is back in stock or available for preorder.
Order in the next 3 hr 44 min to ship today. Details
The Mini MDX2500.1 1 Ohm delivers 2600 Watts RMS through a single full-range channel in a compact and modern form factor.
Built for high-performance systems where space is limited, the MDX Series uses patented technology to achieve high-definition sound with a reliable, space-saving design.
  • A small footprint heavy-duty heatsink makes this micro amplifier easy to install in motorcycles, vehicles, and 4-wheelers, measuring just 8.50″ wide, 5.90″ long, and 2.60″ high.
  • Engineered for maximum efficiency, it delivers powerful output without putting excessive strain on your electrical system.
  • Monoblock 1-channel design provides 2600 watts at 1 Ohm TRUE RMS full-range power using Digital Class D Brazilian technology, ideal for wiring multiple speakers.
  • Includes 4-way protection circuitry for high voltage, low voltage, short circuit, and overcurrent conditions.
  • Top panel features Power, Protection, and Clip LED indicators for convenient system monitoring.
The latest technology on surface mount components ensures best performance against vibration and superior sound quality, allowing enthusiasts and competitors to build the system of their dreams.
Its broad frequency range makes it suitable for a variety of speaker types, including subwoofers, midbass, midrange, full-range, phenolic and titanium drivers, and super tweeters.
Delivers 2600 watts at 1 ohm in a full-range monoblock configuration covering 10 to 25,000 Hz.
The MDX Series is a great fit for motorsports setups like custom motorcycles, ATVs, and Slingshots.
Big power in a small package!
Equipped with a compact, heavy-duty heatsink and integrated cooling fan, this amplifier stays cool even during intense use.
Weighing just 4.05 lbs, it helps your custom build reach maximum output without adding unnecessary weight.
Before Installing
You must follow the instructions for the product’s installation to guarantee optimal performance. If you have any questions, get in touch with us. Before using the amplifier, always follow these guidelines:
  • Make sure the amplifier is switched off before adding or removing any connections. This prevents possible damage to equipment.
  • Keep all cables as far away as possible from the ignition cables, electronic injection modules and starter switch since they may cause noise interference; Minimum recommended installation distance between amplifier is 1.25”.
  • Always use OFC 4 AWG Copper wire for power and ground and minimum of 12 AWG speaker wire and good quality connectors. Copper-clad aluminum wire (CCAW) must not be used. This guarantees reliability and performance.
  • To avoid damaging the cables, make sure that they do not touch sharp metal edges. Important: For this amp use a 150A fuse 12 inches away from the battery as a safety precaution.
    The power rating data is based on equipment from the PRV Audio Group laboratory. Rated power tested with 60Hz to 1KHz sinusoidal signal and THD <= 1%, with resistant load referring to the indicated measurements. The electronic components and the manufacturing process can present manufacturing variations, thus leading to a variation in the measurements made. This amplifier is designed to perform on music applications ( with speakers ), any load test ( resistant load ) is not recommended.
  • Impedance: 1 Ohm
  • Channels: 1 Channel
  • Rated RMS Power at 14.0 V at 1 Ohm: 1x 2600 Watts RMS
  • Rated RMS Power at 14.0 V at 2 Ohm: 1x 1850 Watts RMS
  • Average Efficiency: 84%
  • Operating Voltage: 9 to 16 Volts
  • Musical Current Draw: 149 A
  • Minimal Power Wire Input: (OFC) 4 Gauge wires
  • Built-in Crossover: Variable HPF 5Hz – 80Hz & LPF 50Hz – 1kHz
  • Variable Gain Bass Boost at 50Hz: 0 to +12dB
  • Minimal Speaker Wire Output: 12 Gauge
  • Frequency Response(-3dB): 10 – 25,000 Hz
  • Min. Input Sensitivity for Max. Output: 0.2 to 2v
  • Signal Input: RCA Cables
  • Signal to Noise: >90 dB
  • Protection System: Low & High Supply Voltage / Shortage on Output / Low Impedance on Output
  • Heat Sink Type: Mini Heavy Duty Cast Aluminum
  • Dimensions ( Width x Depth x Height ): 8.50″ x 5.90″ x 2.60″
  • Weight 4.05 lbs.
BrandPRV Audio
ModelMDX2500.1 2 Ohm
Part Number267-8075
UPC810075524291
Weight4.65
Input TypeRCA Line Level-Speaker Level
Output Channels1
Special Features1 ohm Stable
