  • PRV Audio QS2000 2 Ohm QS Series 1-Channel Full-Range Amplifier 2000W
CLEARANCE PRV Audio QS2000 2 Ohm QS Series 1-Channel Full-Range Amplifier 2000W
PRV AudioPart # 294-3558
Model: QS2000 2 Ohms
The PRV Audio QS2000 2 Ohm is a compact monoblock Class D amplifier built for full-range power in demanding car audio systems. With 2000 W RMS at 2 Ohm, it delivers extreme performance in a small aluminum chassis. Engineered for efficiency and reliability, it supports powerful speaker configurations in tight installs.
  • 2000 W RMS @ 2 Ω for high-output full-range performance
  • 81% efficiency via regulated power supply reduces heat and load
  • Full-range frequency response (20 Hz–20 kHz) works with subwoofer or full-range systems
  • Bridgeable to 1500 W @ 4 Ω for flexible system configuration
  • 4-way protection circuitry with top-panel status LEDs ensures safe operation
  • Built-in high/low-pass filters removes need for an extra crossover
  • Compact chassis at 7.4" × 8.66" × 3" for easy installation
CLEARANCE $179.91
MSRP: $224.89
Save $44.98 (20%)
2 In Stock
We'll send you an email when PRV Audio QS2000 2 Ohm QS Series 1-Channel Full-Range Amplifier 2000W is back in stock or available for preorder.
The QS Series amplifiers are built specifically for mids and highs, making them ideal for powering high-output stuntwalls, custom door panels, or any large-scale system demanding louder and more articulate sound reproduction for PRO Audio loudspeakers.
QS Series amplifiers focus on efficient engineering, delivering full-range frequency response performance at an affordable price.
The QS2000 is equipped with a regulated power supply that consistently delivers stable power output. Its design achieves an exceptional efficiency rate of 81%, minimizing energy loss. All of this performance is housed within a compact aluminum heatsink for effective thermal management.
  • 2000 watts true RMS at full range output using Digital Class D Brazilian Technology
  • 1-channel car amplifier stable at 2 ohm for flexible multi-speaker setups
  • High-efficiency full-range design to maximize output from your vehicle's electrical system
  • Compact chassis with 8.66″ x 7.40″ x 3″ dimensions for easy installation in tight spaces
  • 4-way protection circuitry includes high/low voltage, short, and current protection with top-mounted LED indicators
Channels1 Channel
Rated RMS Power at 14.0 V at 2 Ohm
2000 Watts
Rated RMS Power at 14.0 V at 4 Ohm
1500 Watts
The QS Series is our latest line of high-power full bridge amplifiers, designed to deliver exceptional performance at a great value. The QS2000 is stable at 2 Ohm, with a 1 Ohm version also available for added flexibility.
Its broad frequency response makes it suitable for a wide range of applications—including subwoofers, midbass, midrange, full-range speakers, phenolic and titanium drivers, and super tweeters. This all-purpose amplifier is an ideal fit for daily car audio systems that demand both power and versatility.
Built-in high and low pass filters give users the ability to fine-tune the frequency range for their setup—from deep bass to crisp highs.
This proprietary heat dissipation design ensures high airflow, while the cooling fan regulates temperature to keep the amplifier running cool even during the most demanding playlists.
The LED indicator is a convenient built-in feature that lets you monitor your amplifier’s operating status in real time.
The clipping indicator flashes when the amplifier reaches its maximum clean power output, helping you maintain distortion-free performance. All functions are safeguarded by a four-stage intelligent protection circuit for reliable, long-term use.
Popular installation configurations with this amplifier:
1 Channel Configuration for 8 Ohm Components
Its high power output channel allow you to install 4x 8 Ohm Speakers, drivers or tweeters in parallel at 2 Ohm, giving up to 500 watts per component.
1 Channel Configuration for 4 Ohm components
Its high power output channel allow you to install 2x 4 Ohm Speakers in parallel at 2 Ohm, giving up to 1000 watts per component.
Before Installing
You must follow the instructions for the product’s installation to guarantee optimal performance. If you have any questions, get in touch with us. Before using the amplifier, always follow these guidelines:
  • The gauge of the power supply wiring is extremely important to reach the desired amplifier output and for the amplifier’s safety. Not using the recommended wire gauge will result in power loss and overheating of cables. It is important that the power supply cables are the shortest possible length. Always use 100% Copper cables and good quality connectors. This guarantees the sound’s quality and fidelity; To avoid damaging the cables, make sure that they do not touch sharp metal edges. Important: Use a fuse 12 inches away from the battery as a safety precaution
  • Keep all cables as far away as possible from the ignition cables, electronic injection modules and starter switch since they may cause noise interference;
  • In order to avoid interference, the signal cables ( RCA) must be kept away from the original wiring of the vehicle and from any other power supply cable.
  • Amplifier must be installed in a solid and ventilated area. Do not mount amplifier to the back of a subwoofer box; excess vibration may cause damage to the amplifier.
    The power rating data is based on equipment from the PRV Audio Group laboratory. Rated power tested with 100Hz to 1KHz sinusoidal signal and THD <= 1%, with resistant load referring to the indicated measurements. The electronic components and the manufacturing process can present manufacturing variations, thus leading to a variation in the measurements made. This amplifier is designed to perform on music applications ( with speakers ), any load test ( resistant load ) is not recommended.
    PRV Audio products are guaranteed for a period of ONE (1) YEAR from the date of original purchase against any manufacturer’s defects in material and workmanship under normal use.
  • Impedance: 2 Ohm
  • Channels: 1 Channel
  • Rated RMS Power at 14.0 V at 2 Ohm: 2000 Watts RMS
  • Rated RMS Power at 14.0 V at 4 Ohm: 1500 Watts RMS
  • Average Efficiency: 81%
  • Operating Voltage: 9 to 16 Volts
  • Musical Current Draw: 105 A
  • Minimal Power Wire Input: (OFC) 4 Gauge wires
  • Protection Fuse or Circuit Breaker: 150 Amps
  • Minimal Speaker Wire Output: 14 Gauge
  • Frequency Response(-3dB): 20 – 20,000 Hz
  • Min. Input Sensitivity for Max. Output: 200 mV
  • Signal Input: 1 Pair RCA
  • Signal to Noise: >90 dB
  • Protection System: Low & High Supply Voltage / Shortage on Output / Low Impedance on Output
  • Heat Sink Type: Heavy Duty Cast Aluminum
  • Dimensions ( Width x Depth x Height ): 7.40″ x 8.66″ x 3.00″
  • Weight: 4.80 Lbs
The power rated data are based on equipment from the PRV Audio Group laboratory. Frequency reference of 60Hz to 1kHz with THD+N to ≤1 % in impedances referring to the indicated in each measurement. The electronic components and the manufacturing process can present manufacturing variations, thus leading to a variation in the measurements made. This amplifier is designed to perform on music applications (with speakers), any load test (resistant load) is not recommended.
BrandPRV Audio
ModelQS2000 2 Ohms
Part Number294-3558
UPC810075523867
Weight27.05
