  • PRV Audio MDX2000.2 2 Ohm MDX Series 2-Channel Mini Amplifier 2000W
PRV AudioPart # 267-8084
Model: MDX2000.2 2 OHM
Perfect for high-performance systems with limited space, the MDX Series incorporates exclusive patented technologies to deliver high-definition sound quality in a small yet reliable package. Built with motorsports in mind, this tiny yet powerful amplifier is an excellent choice for your motorcycle, ATV, or slingshot.
  • Small but mighty to deliver results without taking up space
  • 90% average efficiency delivers on output without straining your electrical system
  • Built in heatsink and cooling fan to keep the amp cool under the most demanding conditions
  • High level input to make connecting to a factory radio a breeze
  • Configurable to a two or one channel setup
  • Engineered to endure vibration and still deliver a peak performance
  • An excellent choice for motorcycles, ATVs, and slingshots
Your Price: $199.91
Save $49.98 (20%)
We'll send you an email when PRV Audio MDX2000.2 2 Ohm MDX Series 2-Channel Mini Amplifier 2000W is back in stock or available for preorder.
  • This compact micro amplifier features a durable, heavy-duty heatsink and a small footprint, making it easy to install in vehicles, motorcycles, and 4-wheelers. With dimensions of 8.50″ W x 5.90″ L x 2.60″ H, it fits seamlessly into tight spaces.
  • Delivering 2 x 1000 watts at 2 Ohm TRUE RMS, this Digital Class D amplifier uses advanced Brazilian technology, providing the flexibility to power multiple speakers with precision and efficiency.
  • For even greater power, it offers a bridged mode, doubling output to 1 x 2000 watts RMS at a minimum impedance of 4 Ohms, perfect for high-demand systems.
  • Built with the latest surface-mount component technology, it ensures superior vibration resistance and outstanding sound quality, making it the ideal choice for enthusiasts and competitors building their dream audio systems.
One of the standout features of the MDX2000.2 2 Ohm amplifier is its flexibility to operate in 2- or 1-channel configurations, adapting to your specific setup needs.
In 2-channel mode, its high-power output allows you to connect 4x 8 Ohm speakers in parallel, or step it up with 2x 4 Ohm speakers in parallel, delivering an impressive 500 watts per speaker. Alternatively, bridge the amplifier to create a powerful 1-channel configuration.
  • 1000 Watts at 2 Ohm per Channel
  • 2000 Watts at 4 Ohm on Bridged Channel
Designed for motorsport applications, the MDX Series is perfect for custom motorcycles, ATVs, and Slingshots, delivering exceptional performance in a compact package.
High output performance in a compact, space-saving design!
Equipped with a mini heavy-duty heatsink and built-in cooling fan to stay cool during intense playlists.
Weighing just 3.95 pounds, it offers an exceptional performance-to-weight ratio for custom systems.
Popular Installation configurations with this amplifier:
2 Channel Configuration for 8 Ohm Components
Its high-power output channels enable the installation of up to 4x 8 Ohm drivers or tweeters wired in parallel per channel, providing up to 250 watts of power to each component.
2 Channel Configuration for 4 Ohm components
Its high-power output channels enable the installation of up to 2x 4 Ohm drivers or tweeters wired in parallel per channel, providing up to 500 watts of power to each component.
1 Channel Configuration (Bridged) for 8 Ohm components
Its high-power output channels enable the installation of up to 2x 8 Ohm drivers or tweeters wired in parallel per channel, providing up to 1000 watts of power to each component.
Before Installing
You must follow the instructions for the product’s installation to guarantee optimal performance. If you have any questions, get in touch with us. Before using the amplifier, always follow these guidelines:
  • Make sure the amplifier is switched off before adding or removing any connections. This prevents possible damage to equipment.
  • Keep all cables as far away as possible from the ignition cables, electronic injection modules and starter switch since they may cause noise interference; Minimum recommended installation distance between amplifier is 1.25”.
  • Always use OFC 4 AWG Copper wire for power and ground and minimum of 12 AWG speaker wire and good quality connectors. Copper-clad aluminum wire (CCAW) must not be used. This guarantees reliability and performance.
  • To avoid damaging the cables, make sure that they do not touch sharp metal edges. Important: For this amp use a 100A fuse 12 inches away from the battery as a safety precaution.
    The power rating data is based on equipment from the PRV Audio Group laboratory. Rated power tested with 60Hz to 1KHz sinusoidal signal and THD <= 1%, with resistant load referring to the indicated measurements. The electronic components and the manufacturing process can present manufacturing variations, thus leading to a variation in the measurements made. This amplifier is designed to perform on music applications ( with speakers ), any load test ( resistant load ) is not recommended.
  • Impedance: 2 Ohm per Channel
  • Channels: 2 Channel
  • Rated RMS Power at 14.0 V at 2 Ohm: 2x 1000 Watts RMS
  • Rated RMS Power at 14.0 V at 4 Ohm: 4x 660 Watts RMS
  • Bridged Rated RMS Power at 14.0 V at 4 Ohm: 4x 2000 Watts RMS
  • Average Efficiency: 90%
  • Operating Voltage: 8 to 16 Volts
  • Musical Current Draw: 89 A
  • Minimal Power Wire Input: (OFC) 4 Gauge wires
  • Built-in Crossover: Fixed HPF & LPF at 80 Hz
  • Minimal Speaker Wire Output: 12 Gauge
  • Frequency Response(-3dB): 10 – 22,000 Hz
  • Min. Input Sensitivity for Max. Output: 0.2 to 2v
  • Signal Input: RCA Cables
  • Signal to Noise: >90 dB
  • Protection System: High Temperature / Short circuit on Output
  • Heat Sink Type: Mini Heavy Duty Cast Aluminum
  • Dimensions ( Width x Depth x Height ): 8.50" x 5.90" x 2.60"
  • Weight 3.95 lbs.
BrandPRV Audio
ModelMDX2000.2 2 OHM
Part Number267-8084
UPC810075524260
Weight4.45
Input TypeRCA Line Level-Speaker Level
Output Channels2
RMS Power Output (4 Ohms)2100
Special Features2 ohm Stable-Bridgeable
