  • PRV Audio MDX2000.2 1 Ohm MDX Series 2-Channel Mini Amplifier 2000W
NEW PRV Audio MDX2000.2 1 Ohm MDX Series 2-Channel Mini Amplifier 2000W
PRV AudioPart # 267-8094
Model: MDX2000.2 1 Ohm
Perfect for high-performance systems with limited space, the MDX Series incorporates exclusive patented technologies to deliver high-definition sound quality in a small yet reliable package. Built with motorsports in mind, this tiny yet powerful amplifier is an excellent choice for your motorcycle, ATV, or slingshot.
  • Small but mighty to deliver results without taking up space
  • 90% average efficiency delivers on output without straining your electrical system
  • Built in heatsink and cooling fan to keep the amp cool under the most demanding conditions
  • High level input to make connecting to a factory radio a breeze
  • Configurable to a two or one channel setup
  • Engineered to endure vibration and still deliver a peak performance
  • An excellent choice for motorcycles, ATVs, and slingshots
NEW $199.91
MSRP: $249.89
Save $49.98 (20%)
We'll send you an email when PRV Audio MDX2000.2 1 Ohm MDX Series 2-Channel Mini Amplifier 2000W is back in stock or available for preorder.
Order in the next 6 hr 36 min to ship today. Details
The Mini MDX2000.2 2 Ohm delivers 2000 Watts RMS through a two full-range channels in a compact and modern form factor.
Built for high-performance systems where space is limited, the MDX Series uses patented technology to achieve high-definition sound with a reliable, space-saving design.
  • A small footprint heavy-duty heatsink makes this micro amplifier easy to install in motorcycles, vehicles, and 4-wheelers, measuring just 8.50″ wide, 5.90″ long, and 2.60″ high
  • 2 x 1000 watts at 2 Ohm TRUE RMS certified full range output, Digital Class D Brazilian technology allows wiring multiple speakers and sharing power per channel
  • 1 Channel Bridged, combine two channels for doubled output delivering 1 x 2000 watts RMS at a minimum 4 Ohm load on the bridged channel
  • Advanced surface mount component technology provides top performance against vibration and excellent sound quality, giving enthusiasts and competitors the tools to build their ideal system
One of this amp’s standout features is the option to switch between 2 or 1 channel configurations!
In 2 channel mode, the high power output lets you connect 4x 8 Ohm speakers in parallel.
For even greater stereo power, you can run 2x 4 Ohm speakers in parallel for 500 watts per speaker. Or bridge the channels to use it as a single channel amplifier.
1000 Watts at 2 Ohm per Channel
2000 Watts at 4 Ohm on Bridged Channel
The MDX Series is perfect for motorsport use, including custom motorcycles, ATVs, and Slingshots!
Big power in a small package!
Equipped with a compact, heavy-duty heatsink and integrated cooling fan, this amplifier stays cool even during intense use.
Weighing just 3.95 lbs., it helps your custom build reach maximum output without adding unnecessary weight.
Popular Installation configurations with this amplifier:
2 Channel Configuration for 8 Ohm Components
Its high power output channels allow you to install 4x 8 Ohm speakers, drivers or tweeters in parallel per channel, giving up to 250 watts per component.
2 Channel Configuration for 4 Ohm components
Its high power output channels allow you to install 2x 4 Ohm speakers in parallel per channel, giving up to 500 watts per component.
1 Channel Configuration (Bridged) for 8 Ohm components
Its high power output channels allow you to install 2x 8 Ohm speakers in parallel per channel, giving up to 1000 watts per component.
Before Installing
You must follow the instructions for the product’s installation to guarantee optimal performance. If you have any questions, get in touch with us. Before using the amplifier, always follow these guidelines:
  • Make sure the amplifier is switched off before adding or removing any connections. This prevents possible damage to equipment.
  • Keep all cables as far away as possible from the ignition cables, electronic injection modules and starter switch since they may cause noise interference; Minimum recommended installation distance between amplifier is 1.25”.
  • Always use OFC 4 AWG Copper wire for power and ground and minimum of 12 AWG speaker wire and good quality connectors. Copper-clad aluminum wire (CCAW) must not be used. This guarantees reliability and performance.
  • To avoid damaging the cables, make sure that they do not touch sharp metal edges. Important: For this amp use a 100A fuse 12 inches away from the battery as a safety precaution.
    The power rating data is based on equipment from the PRV Audio Group laboratory. Rated power tested with 60Hz to 1KHz sinusoidal signal and THD <= 1%, with resistant load referring to the indicated measurements. The electronic components and the manufacturing process can present manufacturing variations, thus leading to a variation in the measurements made. This amplifier is designed to perform on music applications ( with speakers ), any load test ( resistant load ) is not recommended.
  • Impedance: 2 Ohm per Channel
  • Channels: 2 Channel
  • Rated RMS Power at 14.0 V at 2 Ohm: 2x 1000 Watts RMS
  • Rated RMS Power at 14.0 V at 4 Ohm: 2x 660 Watts RMS
  • Bridged Rated RMS Power at 14.0 V at 4 Ohm: 1x 2000 Watts RMS
  • Average Efficiency: 90%
  • Operating Voltage: 9 to 16 Volts
  • Musical Current Draw: 89 A
  • Minimal Power Wire Input: (OFC) 4 Gauge wires
  • Built-in Crossover: Fixed HPF & LPF at 80 Hz
  • Minimal Speaker Wire Output: 12 Gauge
  • Frequency Response(-3dB): 10 – 22,000 Hz
  • Min. Input Sensitivity for Max. Output: 0.2 to 2v
  • Signal Input: RCA Cables
  • Signal to Noise: >90 dB
  • Protection System: High Temperature / Short circuit on Output
  • Heat Sink Type: Mini Heavy Duty Cast Aluminum
  • Dimensions ( Width x Depth x Height ): 8.50″ x 5.90″ x 2.60″
  • Weight 3.95 lbs.
BrandPRV Audio
ModelMDX2000.2 1 Ohm
Part Number267-8094
UPC810075525892
Weight4.5
Output Channels2
