  • Klipsch Reference Series 7.1 Surround Sound Home Theater Bundle
KlipschPart # 247-2081
Bring the movie theater experience into your home with the Klipsch Reference Series 7.1 Surround Sound Home Theater Bundle. Includes one R-30C 3.5" Center Channel Speaker, two
R-800F 8" Floorstanding Speakers, one R-50M 5.25" Bookshelf Speaker Pair, one R-40M 4" Bookshelf Speaker Pair, and one R-121SW 12" Powered Subwoofer to offer full 7.1 surround sound. With spun-copper TCP woofers, LTS aluminum tweeters, and Tractrix® horns/bass ports, the Reference Series is guaranteed to exceed your highest expectations for movie nights, home concerts, and extended gaming sessions.
  • Spun-copper TCP woofers for clear midrange and punchy bass
  • LTS aluminum tweeters with Tractrix® horn for crisp, detailed highs
  • Rear-firing Tractrix® bass ports enhance low-frequency extension with low distortion
  • High sensitivity and a frequency response of up to 21kHz to provide the full audio spectrum with modest power
  • Integrated Atmos connection simplifies setup of Dolby Atmos compatible height modules
  • High-quality MDF cabinet with scratch-resistant textured wood grain vinyl finish and robust internal bracing
  • Sleek appearance and removable magnetic grille offers a streamlined look and easy cleaning
Your Price: $3,099.94
Out of Stock
Estimated back in stock 5/22/2026
R-800F 8" Floorstanding Speaker (x2)
All New 90° x 90° Tractrix® Horn
The updated horn design, featuring larger outer dimensions, delivers greater power and emotional impact for both music and movies. The increased size allows for directivity control across a wider range of frequencies, creating a more precise and immersive soundstage.
Linear Travel Suspension (LTS) Aluminum Tweeter
A signature feature of Klipsch speakers, the exclusive LTS tweeter with Kapton Suspension reduces distortion for more detailed sound. The tweeter’s aluminum construction is both lightweight and rigid, delivering high efficiency and precise performance.
Spun-Copper Thermoformed Crystalline Polymer Woofers
Drawing on technology from Klipsch’s acclaimed Reference Premiere series, the TCP woofers feature steeper cone angles for smoother response. This refined design enhances accuracy and transparency, delivering clearer, more precise sound reproduction.
High-Quality Cabinet Design & Appearance
Hidden fasteners, an edge-to-edge horn, and low-profile magnetic grilles create a sleek, modern look. The MDF cabinets feature a scratch-resistant, textured wood grain finish that blends seamlessly with your home décor.
Hear Every Word
Tapered array crossovers enhance dispersion between the woofers and tweeters, delivering better midrange clarity. This technology is essential for hearing every detail and nuance in the dialogue of your favorite movies, music, and games.
Slim, High-Quality MDF Cabinet Design
With a sleek, space-saving design that pairs perfectly with modern flat-screen TVs, the next-generation Reference center channel speakers feature hidden fasteners and low-profile magnetic grilles. Their reinforced 3/4" MDF cabinets minimize vibration for greater sonic precision.
Rear Tractrix Port
The rear Tractrix port is precisely tuned to the cabinet and woofers, allowing for optimal airflow while minimizing distortion and turbulence, even at the lowest frequencies.
Refined Atmos Connections
Adding Dolby Atmos is simple with the discreet connections on the back of the speakers. These improved connections help keep wiring out of sight and secure them in place for neater cable management.
All-Digital Amplifier
The R-121SW's integrated all-digital amplifier provides robust power with exceptional efficiency and precise, true-to-source audio reproduction, delivering best-in-class output, detail, and performance.
Front-Firing Driver
The high-performance 12" subwoofer provides deep bass and flexible room placement.
Highly Durable & Versatile Cabinet Design
Reference Subwoofers combine a refined appearance with exceptional durability, allowing them to blend seamlessly into any décor. They feature a scratch-resistant finish, reinforced 3/4" MDF construction, an all-new bracing design to minimize vibration, a front-mounted LED power indicator, and a low-profile grille for acoustic transparency.
Low Pass Crossover & Phase Control
Allows the subwoofer’s low-frequency output to integrate smoothly with other Klipsch speakers while letting you fine-tune the bass to your preference.
Line/LFE Inputs
Reference subwoofers work seamlessly with any home theater receiver, regardless of brand or model.
Reference Redefined
Explore the full lineup of speakers in the latest generation of the iconic Klipsch Reference Redefined series and get ready for an unforgettable listening experience.
Shop Klipsch Reference Series
BrandKlipsch
Part Number247-2081
UPC848864082103
Weight223.85
