NEW Hypex Direct SMPS3kA400 Switched-Mode Power Supply 3000W, 2 x 63 VDC Output
The HypexDirect SMPS3kA400 is a high-power, high-efficiency Safety Class 1 switch mode power supply designed for integration with UcD amplifier modules. It uses large primary electrolytic buffer capacitors to support short-term peak power delivery, while combining a small form factor, low EMI, selectable input voltage range, and remote controlled operation for demanding amplifier builds.
- High power high efficiency design for demanding amplifier projects
- Designed for UcD amplifier modules for easier system integration
- Large primary electrolytic buffer capacitors for stronger short-term peak power delivery
- Small form factor for easier fit in compact amplifier builds
- Low EMI for cleaner operation in audio systems
- Selectable input voltage range for use with different mains standards
- Remote controlled operation for more flexible system control
We'll send you an email when Hypex Direct SMPS3kA400 Switched-Mode Power Supply 3000W, 2 x 63 VDC Output is back in stock or available for preorder.
