  • Hypex Direct Nilai500 Class D Amp Board
NEW Hypex Direct Nilai500 Class D Amp Board
Hypex DirectPart # 221-002
Model: H01U006432
The Hypex Nilai500 is a mono amplifier module built for DIY high-performance amplifier projects. It combines high output power, low distortion, high efficiency, and compact dimensions for custom builds that need strong performance and straightforward integration.
  • Up to 500W at 2Ω 525W at 4Ω and 260W at 8Ω for high-output amplifier designs
  • THD+N of 0.00015% at 100W / 4Ω / 20kHz for extremely low distortion performance
  • Output noise of 9.5 µV at 11.8 dB gain for a quieter signal path
  • Gain adjustable in three steps for easier system matching
  • Discrete buffer stage and regulators for a more refined signal path
  • Dedicated PS500 power supply support for a matched high-end DIY amplifier platform (sold separately)
  • Compact module format for easier integration into custom amplifier builds
NEW $420.00
We'll send you an email when Hypex Direct Nilai500 Class D Amp Board is back in stock or available for preorder.
Order in the next 13 hr 29 min to ship today. Details
Nilai® Class D technology is here!
Whether you are a serious audiophile or a DIY builder aiming to create your own high-performance amplifier, the Nilai500 amplifier module is an outstanding option. It brings together substantial power, excellent efficiency, and refined sound quality in a compact form that is simple to integrate into a custom design.
This major leap in performance brings distortion levels down by a factor of 10, improves power supply noise rejection by 10 times, and lowers output impedance by the same margin. Those numbers are impressive on their own, but their real impact becomes clear the moment you hear the results through your speakers.
The Nilai500 makes a strong impression with its high-output capability, delivering up to 500W at 2 ohms, 525W at 4 ohms, and 260W at 8 ohms. With a maximum output current of 25A and a ±70V voltage swing, it handles dynamic peaks with ease while producing a spacious soundstage and deep, well-controlled bass.
Built on NILAI® technology, the Nilai500 offers exceptional sound quality with very low distortion and a high signal-to-noise ratio, allowing music to be reproduced with impressive clarity and detail. Its efficient Class D design reaches better than 93% efficiency while preserving high-level audio performance and keeping heat generation and power consumption low. At idle, the power stage typically draws only 2.25W, making it a smart choice for high-performance systems that also value energy efficiency.
Designed with great attention to detail, the Nilai500 amplifier module uses carefully chosen high-quality components throughout to support the best possible audio performance. Every part is selected to reduce distortion, improve efficiency, and deliver outstanding sonic clarity, making it a compelling choice for listeners who expect more from their equipment. Its polished exterior also gives a fitting visual hint at the level of engineering inside.
Pairing the Nilai500 with the matching PS500 creates one of the most complete and ready-to-build DIY solutions available.
Features
  • 525W @ 4Ohm
  • THD+N: 0,00015% (-116dB) @ 100W / 4Ohm / 20.000Hz
  • Output noise: 9,5µV @11,8dB gain
  • Gain adjust in 3 steps (11,8 - 21,8 and 27,8)
  • High fidelity components
  • Dedicated high-end power supply PS500
  • Also available in mono & stereo kits
  • Output Power (2Ω): 1 x 500W
  • Output Power (4Ω): 1 x 525W
  • Output Power (8Ω): 1 x 260W
  • Channels: 1
  • HxR Ready: On board
  • Compatible SMPS: PS500DIY
  • Family: Nilai®
  • Technology: Nilai®
This Kit Contains
  • Nilai500 amplifier module
  • Nilai500 cable set - part no. K02U006303
    - 1x Cable asm Z4B50L5 (50cm audio input cable)
    - 1x Cable asm Z2B50L2 (50cm audio output cable)
    - 1x Cable asm Z14A50L1 (50cm SMPS connection cable)
  • Nilai500 mounting set
  • Nilai500 manual
Product Applications
Hypex Direct products can be used in a wide range of DIY applications. Explore the different examples within each application category to help find the right solution for your project.
Preamplifiers
A preamplifier boosts low-level signals up to line level, which is the standard operating level required by your power amplifier. That means a preamp is needed for nearly any audio source. In addition to raising low-level signals, a preamplifier also manages source switching and volume control for line-level inputs.
Examples of available preamplifier solutions:
Available solutions
Switch Mode Power Supply
Notes
1x PreAmplifier Kit
Included
Fully analogue, modular
design, discrete op-amps
1x PreAmplifier Kit
+ 1x PreDIGin add-on
Included
Analogue and digital, modular
Mono Power Amplifier
A mono power amplifier is a self-contained single-channel amplifier unit with its own dedicated power supply and matched amplifier section. Mono power amps are often regarded as one of the best ways to build a high-quality amplifier system. They are commonly used in Hi-Fi and high-end audio systems, but they can also serve in musical instrument amplifier applications.
Examples of available mono power amplifier solutions:
Output Power (4Ω)
Available solutions
Notes
525W1x Nilai500 Mono KitIncluded
180W1x UcD180HG with HXR
+1x SMPS400A180
400W1x UcD400HG with HXR
+1x SMPS400A400
525W1x Nilai500
+1x PS500
800W2x UcD400HG with HXR (BTL)
+1x SMPS1200A400
No DC error protection
1150W2x Nilai500 (BTL)
+1x PS500
Stereo / Dual Power Amplifier
A dual power amplifier contains two power supplies and two amplifier channels, with each channel running from its own dedicated power supply. Both the power supplies and amplifier sections are housed within a single enclosure. A stereo power amplifier uses one power supply to run two amplifier channels within the same enclosure.
Examples of available stereo / dual power amplifier solutions:
Output Power (4Ω)
Available solutions
Notes
300 + 300W1x Nilai500 Stereo KitIncluded
1 pcs for a stereo setup
2 x 525W2x Nilai500 Mono Kit
Included
2 pcs for a stereo setup
180 + 180W
2x UcD180HG with HXR+1x SMPS400A180
for a stereo setup
300 + 300W2x Nilai500
+1x PS500
for a stereo setup
400 + 400W
+1x SMPS1200A400
1150W + 1150W
4x Nilai500 (BTL)
+4x PS500
Multi Channel Amplifier & Immersive Audio
A multichannel amplifier houses multiple amplifier channels within a single enclosure. Common multichannel designs include 4, 8, 16, or even 24 channels. Most use a single power supply, though some models may include two or more power supplies depending on the number of channels and the power demands.
Examples of available multichannel amplifier solutions:
Output Power (4Ω)
Channels
Available solutions
Notes
150W
88x UcD180HG with HXR+1x SMPS400A180
180W22x UcD180HG with HXR
+1x SMPS400A180
180W44x UcD180HG with HXR+1x SMPS1200A180
180W
66x UcD180HG with HXR
+1x SMPS1200A180
300W22x Nilai500
+1x PS500
300W44x Nilai500
+2x PS500
400W
22x UcD400HG with HXR
+1x SMPS1200A400
400W44x UcD400HG with HXR
+1x SMPS1200A400
400W
66x UcD400HG with HXR
+1x SMPS3kA400
No DC error protection, reversing
phase for half of the UcD400 modules
400W
88x UcD400HG with HXR
+1x SMPS3kA400
BrandHypex Direct
ModelH01U006432
Part Number221-002
UPC848864082509
Weight1.75
Board Type1 Channel Mono Amp
Power (RMS/Channel 8 ohms)251 - 500 Watts
Special Features2 ohm Stable
