NEW Hypex Direct SMPS1200A400 Switched-Mode Power Supply 1200W, 2 x 63 VDC Output
The Hypex Direct SMPS1200A400 is a 1200W high-efficiency Safety Class 2 switch mode power supply designed for use with UcD amplifier modules. It is built for audio systems that need stable power delivery across a wide load range in a compact and lightweight format, while also targeting low radiated and conducted electromagnetic interference.
- 1200W output capability for higher-power amplifier projects
- Designed for UcD amplifier modules for easier system matching
- Stable power delivery across a wide load range for demanding audio applications
- Compact and lightweight format for easier integration into amplifier builds
- Low radiated and conducted EMI for cleaner operation in high-end and professional audio systems
- Selectable input voltage range for use with different mains supply standards
- Advanced overcurrent and over temperature protection with DC detection input for added operational protection
We'll send you an email when Hypex Direct SMPS1200A400 Switched-Mode Power Supply 1200W, 2 x 63 VDC Output is back in stock or available for preorder.
