NEW Hypex Direct FusionAmp FA502 Mono 2-Way Plate Amplifier 1000W
The Hypex Direct FusionAmp FA502 is a mono 2-way amplifier module designed for active loudspeaker applications that require high output power. It combines two 500W NCORE Class D amplifier channels with onboard DSP, giving active 2-way systems integrated amplification, signal processing, and broad analogue and digital input flexibility.
- Two 500W NCORE Class D amplifier channels for high-output 2-way active loudspeaker designs
- Onboard DSP with Hypex Filter Design software for adjustment of crossover filters levels and system parameters
- Balanced XLR, RCA, AES, S/PDIF, and optical Toslink inputs for wide source compatibility
- XLR, AES, and S/PDIF loop through connections for easier multi-module system integration
- Three selectable presets for switching between stored filter configurations
- Master-slave capability for building multi-channel active loudspeaker systems
We'll send you an email when Hypex Direct FusionAmp FA502 Mono 2-Way Plate Amplifier 1000W is back in stock or available for preorder.
