  • Hypex Direct FusionAmp FA122 Mono 2-Way Plate Amplifier 250W
NEW Hypex Direct FusionAmp FA122 Mono 2-Way Plate Amplifier 250W
Hypex DirectPart # 221-006
Model: H05U003261
The Hypex Direct FusionAmp FA122 is a mono 2-way amplifier module designed for active loudspeaker applications that need separate amplification channels for low and high frequency drivers. It combines two 125W NCORE Class D amplifier channels with onboard DSP, giving compact active speaker systems integrated amplification, signal processing, and broad input flexibility.
  • Two 125W NCORE amplifier channels for separate low and high frequency driver amplification
  • Onboard DSP with Hypex Filter Design software for adjustment of filters levels and system parameters
  • Balanced XLR, RCA, AES, S/PDIF, and optical Toslink inputs for wide source compatibility
  • XLR, AES, and S/PDIF loop through connections for easier multi-module system integration
  • IIR and FIR filter options with 15 biquads per amplifier for more precise loudspeaker tuning
  • Three selectable presets for switching between stored filter configurations
  • Master-slave capability for building multi-channel active loudspeaker systems
NEW $422.40
We'll send you an email when Hypex Direct FusionAmp FA122 Mono 2-Way Plate Amplifier 250W is back in stock or available for preorder.
Expected back in stock any day
Hypex Direct Fusion Amplifiers
The FusionAmp FA122 is a mono two-way amplifier module developed for active loudspeaker applications. It serves as an integrated solution for systems that need separate amplifier channels for low- and high-frequency drivers.
The module includes two 125 W NCORE® Class D amplifier channels along with onboard DSP. Signal processing is set up through Hypex Filter Design software, giving users the ability to adjust filters, levels, and other system parameters for two-way active loudspeaker designs.
The FA122 offers a variety of analog and digital input options, including balanced analog XLR input with loop through, unbalanced analog RCA input, digital AES input with loop through, digital S/PDIF input with loop through, and optical Toslink input. This makes it easy to integrate with a broad range of analog and digital audio sources.
Optional accessories such as the Fusion Remote Kit or Fusion OLED Display are available for remote operation and system feedback.
Multiple Fusion Amp modules can also be arranged in a master-slave configuration to create multi-channel active loudspeaker systems. The FA122 is intended for applications that call for a compact combination of amplification and DSP in a two-way active loudspeaker design.
Compatible Modules
Features
  • 15 biquads per amplifier
  • Three selectable presets for filters
  • Source selection
  • Signal detect
  • Auto shutdown
  • Master-Slave option
Protections
  • Clip protection
  • Thermal protection
Possible Applications
  • Active Subwoofers
  • Active Guitar Cabinets
  • Active Monitor Loudspeakers
  • Active 2-way Loudspeakers; for home and professional use
  • Output Power (4Ω): 2 x 125W, (1 x 200W in BTL)
  • Output Power (8Ω): 2 x 75W, (1 x 250W in BTL)
  • Inputs: AES/EBU, Optical, RCA, SPDIF, XLR
  • Mains Voltage Input: 100-200Vac / 200-240Vac ±10%
  • Configuration: 1 channel / 2-way
  • Family: Fusion Amp
  • Family Technology: NCORE®
Product Applications
Hypex Direct products can be used in a wide range of DIY applications. Explore the different examples within each application category to help find the right solution for your project.
2-Way Active Loudspeaker
A 2-way speaker is a loudspeaker that has only two drivers, which are a tweeter and a woofer. The woofer covers all frequencies lower than the tweeter. The human ear is more sensitive to mid frequencies, that’s why a speaker system should have at least two types of drivers: one mid-range and the other high-frequency, or tweeter.
Examples of available 2-way active loudspeaker solutions:
Output Power (4Ω)
Available solutions Switch Mode Power Supply
Notes
125 + 125W2x FA122On Board
2pcs for a stereo setup
250 + 250W
2x FA252
On Board2pcs for a stereo setup
500 + 500W
2x FA502
On Board
250 + 100W
2x FA123 (BTL)
On Board
500 + 100W
2x FA253 (BTL)
On Board
1000 + 100W
2x FA503 (BTL)
On Board
3-Way Active Loudspeaker
A 3-way speaker is a loudspeaker that uses three separate drivers: a tweeter, a midrange, and a woofer. Because each driver can be optimized for a specific frequency range, a three-way speaker is able to deliver sound that is clearer, fuller, and more precise.
Examples of available 3-way active loudspeaker solutions:
Output Power (4Ω)
Notes
125 + 125 + 100W2x FA123On Board
250 + 250W + 100W
2x FA253
500 + 500W + 100W
2x FA503
On Board
Single Subwoofer
A subwoofer is an important part of an audio system, adding stronger low frequencies throughout the room. It reproduces bass from roughly 20 to 200 Hz, a range that two-way speakers or surround systems often cannot fully handle on their own. Adding a subwoofer can improve overall sound by making the dynamics feel more impactful and the soundstage seem larger.
Examples of available single subwoofer solutions:
Output Power (4Ω)
250W1x FA251On Board
500W1x FA501
On Board
250W @ 8Ω
1x FA122 (BTL)
On Board
500W @ 8Ω
1x FA252 (BTL)
On Board
1000W @ 8Ω
1x FA502 (BTL)
On Board
Dual Subwoofer
A dual subwoofer system can significantly increase available headroom, giving you greater dynamic range, reduced output compression, lower distortion, and fewer overdrive-related artifacts. Put simply, running two subwoofers delivers cleaner, more accurate bass when played at very high levels.
Examples of available dual subwoofer solutions:
Output Power (4Ω)
125 + 125W
1x FA122
On Board
250 + 250W
1x FA252
On Board
500 + 500W
1x FA502
On Board
1000 + 1000W
2x FA502 (BTL)
On Board
BrandHypex Direct
ModelH05U003261
Part Number221-006
UPC848864082547
Weight3.55
Board TypeMono 2-Way Amplifier
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range< 10 lbs.
Special FeaturesDSP
