  • Hypex Direct FusionAmp FA501 Mono Plate Amplifier 500W
NEW Hypex Direct FusionAmp FA501 Mono Plate Amplifier 500W
Hypex DirectPart # 221-011
Model: H05U003266
The Hypex Direct FusionAmp FA501 is a mono amplifier module designed for 1-way active loudspeaker applications. It is suited for active subwoofers or single-channel active monitors that need higher output power, combining a single 500W NCORE Class D amplifier channel with onboard DSP and flexible analogue input support.
  • 500W NCORE Class D amplifier channel for higher-output active subwoofers and monitors
  • Designed for low frequency applications as well as full-range 1-way loudspeaker designs
  • Balanced XLR input and loop through plus RCA and high-level inputs for flexible system integration
  • Front panel gain control for direct level adjustment
  • IIR and FIR filter options with 15 biquads for more precise system tuning
  • Three selectable presets for switching between stored filter settings
  • Master-slave capability for building multi-channel active loudspeaker systems
NEW $501.60
We'll send you an email when Hypex Direct FusionAmp FA501 Mono Plate Amplifier 500W is back in stock or available for preorder.
Order in the next 2 hr 39 min to ship today. Details
Hypex Direct Fusion Amplifiers
The FusionAmp FA501 is a mono amplifier module developed for one-way active loudspeaker applications. It is well suited for active subwoofers or single-channel active monitors that require higher output power.
The module includes a single 500 W NCORE® Class D amplifier channel. It is designed to deliver stable output for low-frequency applications as well as full-range one-way loudspeaker designs.
The FA501 supports several input options, including balanced analog XLR input with loop through, unbalanced analog RCA input, and high-level input. This allows it to integrate with a wide range of source equipment and system configurations. A front-panel gain control is included for level adjustment.
Optional accessories such as the Fusion Remote Kit or Fusion OLED Display are available for remote operation and system feedback.
Multiple Fusion Amp modules can be combined in a master-slave configuration to create multi-channel active loudspeaker systems. The FA501 is intended for applications that need a compact integrated amplifier solution with higher power capability.
Compatible Modules
Features
  • 15 biquads per amplifier
  • Three selectable presets for filters
  • Source selection
  • Signal detect
  • Auto shutdown
  • Master-Slave option
Protections
  • Clip protection
  • Thermal protection
Possible Applications
  • Active Subwoofers
  • Active Guitar Cabinets
  • Active Monitor Loudspeakers
  • Active 1-way Loudspeakers; for home and professional use
  • Output Power (4Ω): 1 x 500W
  • Output Power (8Ω): 1 x 270W
  • Mains voltage input: 100-120Vac / 200-240Vac ±10%
  • Family: Fusion Amp
  • Family Technology: NCORE®
  • Dimensions: 11.02" x 5.31" x 2.17"
  • Weight: 2.04 lbs.
Product Applications
Hypex Direct products can be used in a wide range of DIY applications. Explore the different examples within each application category to help find the right solution for your project.
2-Way Active Loudspeaker
A 2-way speaker is a loudspeaker that has only two drivers, which are a tweeter and a woofer. The woofer covers all frequencies lower than the tweeter. The human ear is more sensitive to mid frequencies, that’s why a speaker system should have at least two types of drivers: one mid-range and the other high-frequency, or tweeter.
Examples of available 2-way active loudspeaker solutions:
Output Power (4Ω)
Available solutionsSwitch Mode Power Supply
Notes
125 + 125W2x FA122On Board
2pcs for a stereo setup
250 + 250W
2x FA252
On Board2pcs for a stereo setup
500 + 500W
2x FA502
On Board
250 + 100W
2x FA123 (BTL)
On Board
500 + 100W
2x FA253 (BTL)
On Board
1000 + 100W
2x FA503 (BTL)
On Board
3-Way Active Loudspeaker
A 3-way speaker is a loudspeaker that uses three separate drivers: a tweeter, a midrange, and a woofer. Because each driver can be optimized for a specific frequency range, a three-way speaker is able to deliver sound that is clearer, fuller, and more precise.
Examples of available 3-way active loudspeaker solutions:
Output Power (4Ω)
Notes
125 + 125 + 100W2x FA123On Board
250 + 250W + 100W
2x FA253
500 + 500W + 100W
2x FA503
On Board
Single Subwoofer
A subwoofer is an important part of an audio system, adding stronger low frequencies throughout the room. It reproduces bass from roughly 20 to 200 Hz, a range that two-way speakers or surround systems often cannot fully handle on their own. Adding a subwoofer can improve overall sound by making the dynamics feel more impactful and the soundstage seem larger.
Examples of available single subwoofer solutions:
Output Power (4Ω)
250W1x FA251On Board
500W1x FA501
On Board
250W @ 8Ω
1x FA122 (BTL)
On Board
500W @ 8Ω
1x FA252 (BTL)
On Board
1000W @ 8Ω
1x FA502 (BTL)
On Board
Dual Subwoofer
A dual subwoofer system can significantly increase available headroom, giving you greater dynamic range, reduced output compression, lower distortion, and fewer overdrive-related artifacts. Put simply, running two subwoofers delivers cleaner, more accurate bass when played at very high levels.
Examples of available dual subwoofer solutions:
Output Power (4Ω)
125 + 125W
1x FA122
On Board
250 + 250W
1x FA252
On Board
500 + 500W
1x FA502
On Board
1000 + 1000W
2x FA502 (BTL)
On Board
BrandHypex Direct
ModelH05U003266
Part Number221-011
UPC848864082592
Weight3.65
Power (RMS/Channel 8 ohms)251 - 500 Watts
Weight Range< 10 lbs.
Special FeaturesDSP
