  • Tang Band T1-1942S Speaker Module 5-1/4" x 2-1/8"
2 Questions, 8 Answers or
Tang Band
Part #264-946
Tang Band
Part #264-946
Model: T1-1942S
Tang Band's T1-1942S features a passive radiator-assisted, polypropylene 46 mm driver that plays from 105 to 20,000 Hz in an ultra-small package so that you can design modern speakers never before thought possible.
  • 46 mm polypropylene-composite inverted dome driver
  • Plays down to 80 Hz through the use of a passive radiator
  • Self-contained 6.06" H x 2.13" W x 1.19" D design
  • The easiest way to add audio capability to almost anything
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $42.10
MSRP: $63.99
Save $21.89 (34%)
Quantity:Qty: 50+$42.10/ea
Out of Stock
Ships in 90-120 days, minimum order quantity 50 pcs.
Alert Me When Available
The T1-1942S speaker module from Tang Band and is built around a passive radiator assisted, polypropylene-composite 46 mm dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel tv speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 80 Hz high pass filter for the best possible sound. Higher power handling and output is possible through the use of multiple modules.
BrandTang Band
ModelT1-1942S
Part Number264-946
UPC848864043739
Weight0.45
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Frequency Response78 to 20,000Hz
Sensitivity81dB 2.83V/1m
Cone MaterialPoly Composite
Magnet MaterialNeodymium
Overall Outside Diameter5.25" (With mounting tabs: 6.06") x 2.125"
Depth1.19"
