  • Russound D1290 D Series 12-Channel Digital Amplifier 1U 90 WPC
RussoundPart # 247-1920
Model: D1290
The Russound D1290 is a 12-channel digital amplifier designed for large-scale residential or commercial audio systems. With flexible routing, configurable filters, and a compact 1U design, it offers a versatile way to power multiple zones with precision and reliability.
  • Class D digital amplification for efficient, cool-running performance
  • Bridgeable channels provide flexible power options per zone
  • Shared or individual inputs let each zone play the same or different sources
  • Selectable Full Range, High Pass, or Low Pass filters for zone tuning
  • Three control modes: Always On, Signal Sensing, or 12V Trigger
  • Thermal fan cooling maintains consistent performance under load
  • 1U rackmount chassis conserves space in system installations
Dayton Audio MA1260 Multi-Zone 12 Channel Amplifier 60WPC
Price: $749.98Part # 300-8150
See all items in Multi-Zone Amplifiers
Your Price: $1,499.00
We'll send you an email when Russound D1290 D Series 12-Channel Digital Amplifier 1U 90 WPC is back in stock or available for preorder.
Russound’s D-Series amplifiers are known for premium performance, reliability, and long-lasting durability, serving as the foundation of professional audio installations worldwide. The latest generation continues this tradition of excellence with refined engineering and enhanced versatility.
The D1290 is designed to expand audio systems into additional rooms or zones or to provide greater output for large spaces and outdoor areas that demand higher volume levels.
Delivering up to 90 watts per channel, the D1290 features an advanced digital design that allows for a smaller chassis than any previous Russound amplifier. At just one rack unit in height, it achieves compact efficiency without sacrificing power or capability. A primary goal of the redesign was to reduce size while maintaining—and even increasing—the range of available features.
The D1290 accomplishes this with a new, easily configurable output option that allows customization for various applications, from powering standard speakers to driving passive subwoofers in any area of the home, indoors or outdoors.
Providing installers with flexibility, reliability, and strong value, the D1290 delivers the exceptional sound quality and robust performance that Russound customers expect.
  • Amplifier Channels: 12 channels 6 independent zones
  • Bridge: Yes
  • Frequency Response: 20Hz to 20kHz +/-3dB at 1W output into 4 or 8 Ohms
  • Fuse Rating: 10A, 250V FA
  • Input Impedance: >22k ohms Line Input
  • Input Sensitivity:
    -620 mV for 90W @ 1kHz 4 Ohm One Zone
    -690 mV for 45W @ 1kHz 8 Ohm One Zone
  • Power Output:
    -90W /Channel, 1kHz One Zone Driven - 4 Ohm
    -45W /Channel, 1kHz, One Zone Driven - 8 Ohm
    -180W, 1kHz, One Zone Driven - 8 Ohm Bridged
  • Power Requirement(s):
    -North American Model: 115-120VAC, 60Hz (800W Max)
    -International Model (D1290i):220-240VAC, 50Hz (800W Max)
  • Signal to Noise Ratio: >90dB A-weighted
  • Speaker Connection(s): Detachable Screw-down, up to 12AWG
  • Trigger Input(s): 12V, Global
  • Line Input: Selectable: Bus A, Bus B, Zone
BrandRussound
ModelD1290
Part Number247-1920
UPC612934853913
Weight13.5
Weight Range< 10 lbs.
Special FeaturesBridgeable
