  • Russound D890 D Series 8-Channel Digital Amplifier 1U 90 WPC
NEW Russound D890 D Series 8-Channel Digital Amplifier 1U 90 WPC
RussoundPart # 247-1919
Model: D890
The Russound D890 is an 8-channel digital amplifier tailored for modern multiroom audio systems. It packs powerful amplification and configurable filters into a slim 1U chassis.
  • Uses Class D amplification for efficient, cool operation
  • Built-in filters let you tailor frequency response per zone
  • Flexible control modes including Always On, Signal Sensing, and 12V trigger
  • Bridgeable channels enable combining outputs for more power in a single zone
  • Slim 1U chassis saves rack space while maintaining full functionality
  • Robust protection circuitry guards against overload and faults
NEW $1,149.00
We'll send you an email when Russound D890 D Series 8-Channel Digital Amplifier 1U 90 WPC is back in stock or available for preorder.
Order in the next 2 hr 58 min to ship today. Details
Russound’s D-Series amplifiers represent the standard for premium performance, reliability, and durability, serving as the foundation of professional audio installations worldwide. The latest generation builds on this proven legacy and is available in three powerful models: D890 with 8 channels (4 zones), D1290 with 12 channels (6 zones), and D1675 with 16 channels (8 zones).
Each model is engineered to expand audio systems into additional rooms or zones, or to provide higher output for large spaces and outdoor areas requiring greater volume.
Delivering up to 90 watts per channel on the D890 and D1290, and 75 watts per channel across 16 channels on the D1675, these amplifiers use advanced digital circuitry that allows for smaller chassis sizes than any previous Russound generation. The D890 and D1290 fit into just one rack unit, while the D1675 occupies only two.
Reducing amplifier size was a key design goal, but Russound also added more functionality than ever before. The new D-Series introduces flexible configuration options, allowing installers to tailor audio output for a wide range of applications—from traditional speaker setups to powering passive subwoofers both indoors and outdoors.
With enhanced flexibility, robust design, and exceptional sound quality, the new D-Series gives installers the tools to meet their clients’ needs while maintaining project budgets and exceeding performance expectations.
  • Amplifier Channels: 8 channels 4 independent zones
  • Bridge: Yes
  • Frequency Response: 20Hz to 20kHz +/-3dB at 1W output into 4 or 8 Ohms
  • Fuse Rating: 6.3A, 250V FA
  • Input Impedance: >22k ohms Line Input
  • Input Sensitivity:
    -620 mV for 90W @ 1kHz 4 Ohm One Zone
    -690 mV for 45W @ 1kHz 8 Ohm One Zone
  • Power Output:
    -90W /Channel, 1kHz One Zone Driven - 4 Ohm
    -45W /Channel, 1kHz, One Zone Driven - 8 Ohm
    -180W, 1kHz, One Zone Driven - 8 Ohm Bridged
  • Power Requirement(s):
    -North American Model: 115-120VAC, 60Hz (600W Max)
    -International Model (D890i):220-240VAC, 50Hz (600W Max)
  • Signal to Noise Ratio: >90dB A-weighted
  • Speaker Connection(s): Detachable Screw-down, up to 12AWG
  • Trigger Input(s): 12V, Global
  • Line Input: Selectable: Bus A, Bus B, Zone
BrandRussound
ModelD890
Part Number247-1919
UPC612934853906
Weight12.8
