  • Dayton Audio MA1260 Multi-Zone 12 Channel Amplifier 60WPC
Dayton AudioPart # 300-8150
Model: MA1260
The Dayton Audio MA Series multi-channel amplifiers deliver the perfect balance of power, efficiency, flexibility, and reliability. Featuring both global and individual channel inputs, these amplifiers can be configured for a wide range of applications. Their efficient, lightweight Class D design keeps energy consumption low without compromising on output performance.
  • Powerful Multi-Channel Amplification – 12 Class D channels delivering 60W RMS per channel at 8 ohms or up to 120W per zone in bridged mode, perfect for driving whole-home or theater systems
  • Flexible Audio Routing – Use 8 independent line inputs, 2 stereo bus inputs, or a combination of both to send music exactly where you want it
  • Whole-Home or Single-Room Use – Distribute audio to 6 zones for up to 6 rooms, or with an appropriate processor, power a full multi-channel home theater setup with ease.
  • Smart Installation Features – 2RU rack-mountable design with removable ears, manual or auto-on signal sensing, and 12V trigger input for automation systems
  • Clean, Detailed Sound – Wide 20Hz–20kHz frequency response, high 106 dB signal-to-noise ratio, and less than 1% THD for professional-quality audio
  • Efficient & Reliable – Lightweight Class D design runs cool while delivering consistent, dependable performance in demanding setups
  • Heavy Duty Connectors – Use up to 14 AWG stranded two-conductor loudspeaker wire with Phoenix style connectors for maximum power transfer
Your Price: $749.98
Save $284.01 (27%)
We'll send you an email when Dayton Audio MA1260 Multi-Zone 12 Channel Amplifier 60WPC is back in stock or available for preorder.
Order in the next 0 hr 5 min to ship today. Details
Dayton Audio MA1260 8 Input 60W X 12 Channel Class D Amplifier
The best solution for the challenges of multi-channel audio
The Dayton Audio MA1260 features a Class-D output circuit that delivers superior audiophile sound quality and stable performance. Each of the installation's zones can benefit from the MA1260's clean audio reproduction and exceptional functionality. The MA1260 can be stacked with other audio components and includes removable ears for mounting in standard audio racks (2RU).
Key Specs:
  • Channels: 12
  • Power Handling @ 8ohms (RMS): 45 Watts
  • Power Handling @ 4ohms (RMS): 80 Watts
  • Frequency Response: 8Hz- 48kHz
  • Inputs: 2 Stereo Bus Inputs, 1 mono input per channel
  • Outputs: 2 Stereo Bus Outputs
Flexibility Redefined
The Dayton Audio MA1260 12-channel amplifier offers outstanding flexibility, making it an ideal choice for a wide range of whole-home audio configurations. Use it with a single global music streamer, assign individual streamers to each of its four zones, or pair it with a multi-channel matrix like Dayton’s own Matrix88 for complete app-based control. No matter the setup, the MA1260 delivers powerful, high-quality sound to up to six rooms with ease.
Home Theater Powerhouse
The Dayton Audio MA1260 is equally capable in a single-room setup, serving as the main power source for multi-channel surround systems when your receiver needs extra muscle or lacks built-in amplification. For even greater output, each of the six zones can be bridged to deliver up to 120 watts RMS per channel into an 8-ohm load.
Six Bridgeable Stereo Amps in One Chassis
The system features two versatile Bus inputs that can be routed to any channel, giving you the ability to distribute shared audio sources across multiple zones with ease. For greater control, each channel can also be configured with its own dedicated input, allowing independent source selection when needed.
For applications that demand higher output, two channels can be easily bridged together with the flip of a single switch. This configuration combines their power into a single, more robust channel, effectively boosting the total wattage available to that zone.
Inputs and Outputs
Two common or BUS inputs feed audio signals from standard line-level audio sources to any or all channels. Each of the twelve channels has its own dedicated input and independent level adjustment to provide further flexibility. By simply flipping a single switch, two channels can be bridged to increase the total power output for that zone. This is helpful when extra power is needed in certain areas.
Convenient Features
Manual, automatic on/off, or triggered 12V input turn-on modes facilitate easy integration into automated systems. For quick and easy troubleshooting of the system, each pair of channels or zones has a bi-color LED to indicate its operational status. Use 14-18 AWG stranded two-conductor loudspeaker wire with Phoenix style connectors.
NOTE: See setup addendum when using in-wall volume controls. You can find this document under "Manuals and Resources" on this page.
MA1260 Specifications
Channels12
Power Handling (RMS)
45 WPC @ 8 ohm
Power Handling (RMS)80 WPC @ 4 ohm
Power Handling (Bridged)120 W @ 8 Ohm
Frequency Response20 Hz - 20 kHz
Input Sensitivity
450 mV
SNR, A-Weighted110 dB
Total Harmonic Distortion<1% @ rated power
Inputs4 Individual Line Inputs, 2 Stereo Bus Inputs
Outputs2 Stereo Bus Outputs
Power Requirements120 - 240 VAC
Standby Consumption0.46 Watts
Dimensions19" W x 14.25" D x 4" H (width includes rack ears)
Weight40 lbs.
In The Box
  • 1 x MA1260 Amplifier
  • 2 x Rack Mounting Brackets
  • 1 x Rack Mount Installation Kit
  • 6 x 4 pole Phoenix Connectors
  • 1 x 6' Power Cable
  • 1 x User Manual
ModelMA1260
Part Number300-8150
UPC848791001215
Weight40
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range40 to 49 lbs.
Special FeaturesRack Mountable
