  • GRS 10" Woofer Surface Mount Poly Cone 8 Ohm 10SMP-8
NEW GRS 10" Woofer Surface Mount Poly Cone 8 Ohm 10SMP-8
GRSPart # 292-872
Model: 10SMP-8
The GRS 10SMP-8 is a versatile 10" 8 ohm woofer designed for easy surface mounting and exceptional reliability. It features a damped poly cone and a rubber surround, which work together to produce natural and well-controlled sound output. Additionally, it includes a copper cap that minimizes inductance and distortion. The vented pole piece and aluminum voice-coil former enhance cooling, effectively reducing power compression. With its lightweight 2-layer coil, the 10SMP-8 is ideally suited for sealed enclosures and larger 3-way speaker systems making it an excellent choice for anyone looking to upgrade their older home audio setups.
  • Low profile frame supports surface mounting for easy installation
  • Copper cap in the motor lowers inductance and distortion for more accurate response
  • Vented pole piece and aluminum voice coil former improve cooling to limit compression
  • Excellent performance in sealed boxes, great choice for larger 3-way designs
  • Damped poly cone with rubber surround controls resonance for a smooth natural response
GRS 10" Woofer Surface Mount Poly Cone 4 Ohm 10SMP-4
Price: $51.99Part # 292-870
See all items in Woofers
NEW $51.99
MSRP: $68.99
Save $17.00 (25%)
We'll send you an email when GRS 10" Woofer Surface Mount Poly Cone 8 Ohm 10SMP-8 is back in stock or available for preorder.
Order in the next 9 hr 48 min to ship today. Details
The GRS 10SMP-8 is a 10" woofer with a low profile frame designed for easy surface mounting, making it a great choice for new installations or retrofits in older speaker systems. Its design focuses on accurate response and long-term reliability, ensuring that you can enjoy consistent performance for years to come.
Crafted with a damped poly cone and rubber surround, this woofer provides a natural and well-controlled response. The inclusion of a copper cap in the motor helps to reduce inductance and distortion, allowing for clearer and more accurate reproduction. Additionally, an integrated foam gasket ensures an airtight seal within the cabinet. The vented pole piece and aluminum former work together to keep the voice coil cool, minimizing power compression and maintaining sound integrity even at higher volumes. Thanks to a lightweight 2-layer coil the 10SMP-8 delivers good efficiency for high output without requiring a ton of power.
Optimized for use in sealed enclosures, the 10SMP-8 is particularly well-suited for larger 3-way speaker designs. In addition, this driver is compatible with many classic speaker systems making it a great option for breathing new life into your existing sound system.
BrandGRS
Model10SMP-8
Part Number292-872
UPC848864079875
Weight10
Nominal Diameter10"
Bolt Circle Diameter10.5
Power Handling (RMS)70 Watts
Power Handling (MAX)140 Watts
Frequency Response24 - 2,000Hz
Sensitivity87.5dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)29Hz
DC Resistance (Re)6.1Ω
Voice Coil Inductance (Le)0.46mH
Mechanical Q (Qms)2.75
Electromagnetic Q (Qes)0.73
Total Q (Qts)0.58
Compliance Equivalent Volume (Vas)2.86ft³
Mechanical Compliance of Suspension (Cms)0.49mm/N
BL Product (BL)9.6T·m
Diaphragm Mass Inc. Airload (Mms)61g
Surface Area of Cone (Sd)340cm²
Cone MaterialPoly
Voice Coil FormerAluminum
Overall Outside Diameter11"
Baffle Cutout Diameter9.2"
Depth4.5"
# Mounting Holes5
Sealed Volume2.2ft³
Sealed F343Hz
Vented Volume2.2ft³
Vented F327Hz
