  • FaitalPRO 5HX140 5" Neodymium Professional Coaxial Driver 8 Ohm
FaitalPROPart # 294-1082
Model: 5HX140
The FaitalPRO 5HX140 is a 5″ (130 mm) coaxial loudspeaker designed for compact professional systems that demand full-range coverage from a single unit. It combines a 5″ low-frequency driver and a 0.98″ (25 mm) high-frequency dome in a unified design, offering streamlined integration and broad bandwidth.
  • Frequency range 100 Hz–8,000 Hz (LF) and 1,500 Hz–18,000 Hz (HF)
  • LF voice coil 1.46″ (37 mm) aluminum wound on a Kapton former
  • Dispersion angle of 90° for controlled coverage
  • Made in Italy
Your Price: $257.00
We'll send you an email when FaitalPRO 5HX140 5" Neodymium Professional Coaxial Driver 8 Ohm is back in stock or available for preorder.
Order in the next 13 hr 28 min to ship today. Details
With its dual-range design the 5HX140 delivers full-band performance from a single compact unit. The 5″ low-frequency driver handles 120 W AES while the high-frequency dome covers the upper range with 101 dB sensitivity, allowing clear articulation even at moderate levels. The 1.46″ (37 mm) aluminum voice coil on a Kapton former in the LF section gives good thermal stability, while the wide bandwidth of both sections ensures broad-range fidelity. The 90° dispersion provides consistent coverage in install environments, and the shallow 2.91″ (74 mm) depth aids flush-mounting in tight spaces. This coaxial driver is a solid choice for compact but capable professional audio systems.
BrandFaitalPRO
Model5HX140
Part Number294-1082
UPC848864081878
Weight3
Nominal Diameter5"
Bolt Circle Diameter5.47
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Impedance8Ω
Frequency Response100 to 8000Hz
Sensitivity91dB 2.83V/1m
Voice Coil Diameter1.46"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)6Ω
Mechanical Q (Qms)4.8
Electromagnetic Q (Qes)0.45
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)0.12ft³
Mechanical Compliance of Suspension (Cms)0.34mm/N
BL Product (BL)8T·m
Diaphragm Mass Inc. Airload (Mms)7.5g
Maximum Linear Excursion (Xmax)5.1mm
Surface Area of Cone (Sd)85cm²
Magnet MaterialNeodymium
Overall Outside Diameter5.05"
Baffle Cutout Diameter4.65"
Depth2.91"
Sealed Volume0.683ft³
Sealed F322.4Hz
Vented Volume2.967ft³
Vented F310.17Hz
