  • FaitalPRO 12HX500 12" Neodymium Professional Coaxial Driver 8 Ohm
NEW FaitalPRO 12HX500 12" Neodymium Professional Coaxial Driver 8 Ohm
FaitalPROPart # 294-1086
Model: 12HX500
The 12HX500 is a 12" (300 mm) coaxial loudspeaker that integrates a full-range low-frequency driver with a high-frequency compression section, designed for professional audio systems that require efficient full-band coverage from a single unit.
  • 400 W AES (800 W program) handling for the LF driver and 90 W AES for the HF
  • 95 db Sensitivity for the LF section and 105 db for the HF section
  • LF voice coil diameter 3" (77 mm); HF voice coil 2.9" (74 mm)
  • Frequency range: LF 50 Hz to 4,000 Hz; HF 500 Hz to 20,000 Hz
  • Overall diameter 12.44" (316 mm), mounting depth 6.89" (175 mm)
  • Triple-roll cloth surround in LF section and twin-ring neodymium magnet systems
  • Made in Italy
NEW $880.00
We'll send you an email when FaitalPRO 12HX500 12" Neodymium Professional Coaxial Driver 8 Ohm is back in stock or available for preorder.
The 12HX500 delivers full-range performance by combining a 12" (300 mm) low-frequency driver section with a dedicated high-frequency section in a coaxial design. The LF section is rated for 400 W AES power handling with a sensitivity of 95 dB, offering 50 Hz to 4,000 Hz. The HF section adds 90 W AES capacity and 105 dB sensitivity to deliver articulate highs from 500 Hz up to 20,000 Hz. Both voice coils are robust; 3" (77 mm) for LF and 2.9" (74 mm) for HF to support thermal and mechanical demands. With a frequency span from 50 Hz through 20,000 Hz, this driver is well suited for simplified cabinet designs where full-band coverage is desired. The unit’s physical footprint is a 12.44" (316 mm) diameter and 6.89" (175 mm) depth, making it compatible with many standard 12" enclosure formats while achieving high output efficiency. Mechanical elements like the triple-roll LF surround and neodymium ring magnets enable high excursion and sustained performance under load, making the 12HX500 a reliable choice for professional installations and live reinforcement systems.
BrandFaitalPRO
Model12HX500
Part Number294-1086
UPC848864081915
Weight13.2
Nominal Diameter12"
Bolt Circle Diameter11.75
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response50 to 4000Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)55Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.57mH
Mechanical Q (Qms)7.3
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)2.04ft³
Mechanical Compliance of Suspension (Cms)0.14mm/N
BL Product (BL)17.4T·m
Diaphragm Mass Inc. Airload (Mms)58.88g
Maximum Linear Excursion (Xmax)9.25mm
Surface Area of Cone (Sd)540cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.44"
Baffle Cutout Diameter11.02"
Depth6.89"
Sealed Volume8.991ft³
Sealed F3136.8Hz
Vented Volume35.36ft³
Vented F366.23Hz
