  • FaitalPRO 10HX240 10" Neodymium Professional Coaxial Driver 8 Ohm
FaitalPROPart # 294-1085
Model: 10HX240
The 10HX240 is a 10″ (250 mm) coaxial driver combining a full-range low-frequency section and an integrated high-frequency compression driver in a single compact unit. It is designed to deliver full-band coverage and high output efficiency for professional sound systems where space and performance are both critical. Its high sensitivity and tailored LF/HF power ratings make it a versatile choice for installation and performance applications.
  • LF AES power handling 250 W and program 500 W
  • LF sensitivity 96 dB; HF AES 30 W with HF sensitivity 107 dB
  • Frequency range: LF 65–4,000 Hz, HF 1,500–20,000 Hz
  • LF voice coil diameter 2.56″ (65 mm); HF voice coil 1.46″ (37 mm)
  • 110° nominal dispersion angle for the HF section
  • Aluminum demodulation ring in LF section to reduce distortion
  • Made in Italy
Your Price: $574.00
We'll send you an email when FaitalPRO 10HX240 10" Neodymium Professional Coaxial Driver 8 Ohm is back in stock or available for preorder.
The 10HX240 provides a seamless full-range solution in a single compact driver, ideal for systems where cabinet space is limited but clarity and output are still required. The low-frequency section handles 250 W AES (500 W program) with a sensitivity of 96 dB, delivering 65 Hz up to 4,000 Hz. The high-frequency compression driver section is rated at 30 W AES with a 107 dB sensitivity, extending cleanly from 1,500 Hz up to 20,000 Hz. The LF voice coil diameter of 2.56″ (65 mm) and the HF coil of 1.46″ (37 mm) ensure robust thermal and mechanical margins. With a shallow depth of 5.39″ (137 mm) and large diameter of 10.28″ (261 mm), the 10HX240 integrates easily into cabinet systems without sacrificing performance. The inclusion of neodymium ring magnets in both sections and an aluminum demodulation ring in the LF section help maintain linearity and low distortion, making this coaxial driver a strong choice for pro-audio installations and touring applications requiring full-band performance.
BrandFaitalPRO
Model10HX240
Part Number294-1085
UPC848864081908
Weight10.15
Nominal Diameter10"
Bolt Circle Diameter9.69
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Impedance8Ω
Frequency Response65 to 4000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter2.56"
Resonant Frequency (Fs)65Hz
DC Resistance (Re)5.3Ω
Voice Coil Inductance (Le)0.45mH
Mechanical Q (Qms)3.3
Electromagnetic Q (Qes)0.3
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)1.12ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)15.5T·m
Diaphragm Mass Inc. Airload (Mms)31.6g
Maximum Linear Excursion (Xmax)7.37mm
Surface Area of Cone (Sd)347cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter10.28"
Baffle Cutout Diameter9.06"
Depth5.39"
Sealed Volume2.513ft³
Sealed F3217.5Hz
Vented Volume8.049ft³
Vented F3118.7Hz
