  • FaitalPRO 8HX240 8" Neodymium Professional Coaxial Driver 8 Ohm
NEW FaitalPRO 8HX240 8" Neodymium Professional Coaxial Driver 8 Ohm
FaitalPROPart # 294-1084
Model: 8HX240
The 8HX240 is an 8″ (200 mm) coaxial loudspeaker designed for compact professional systems needing unified full-range output from a single driver. It integrates a full-size LF driver with a high-frequency section to simplify system design and installation.
  • LF frequency range from 70 Hz to 4,000 Hz; HF from 1,200 Hz to 20,000 Hz
  • LF voice coil diameter of 2.56″ (65 mm); HF voice coil diameter of 1.46″ (37 mm)
  • Dispersion angle of 100° for the HF section for wide coverage
  • Neodymium ring magnet structures for both LF and HF sections
  • Triple-roll surround on the LF driver for excursion control and durability
  • Made in Italy
See all items in Pro Coaxial Full-Range Speakers
NEW $489.00
We'll send you an email when FaitalPRO 8HX240 8" Neodymium Professional Coaxial Driver 8 Ohm is back in stock or available for preorder.
Order in the next 4 hr 45 min to ship today. Details
The 8HX240 combines both an 8″ (200 mm) low-frequency driver section and a high-frequency compression section into a single coaxial unit, making it ideal for compact cabinet designs that demand full-band coverage. The LF section offers a strong 250 W AES power rating with a sensitivity of 94 dB, while the HF section delivers 107 dB sensitivity and handles 30 W AES to cover the upper band with clarity. A 2.56″ (65 mm) LF voice coil and a 1.46″ (37 mm) HF voice coil help ensure thermal stability and efficient output. With a frequency range of 70 Hz to 4,000 Hz on the LF band and 1,200 Hz to 20,000 Hz on the HF band, system designers gain a versatile driver in a compact form. The mechanical footprint is optimized for install use, featuring an overall diameter of 8.81″/8.18″ (223.75 mm/207.9 mm) and a depth of just 4.94″ (125.5 mm). The 100° dispersion angle of the HF section delivers broad high-frequency coverage without requiring large horn structures. Neodymium ring magnet structures drive both sections efficiently while maintaining a manageable weight. The triple-roll surround on the LF section enhances excursion control and long-term reliability under demanding use in installs or portable systems.
BrandFaitalPRO
Model8HX240
Part Number294-1084
UPC848864081892
Weight9.05
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response70 to 4000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2.56"
Resonant Frequency (Fs)70Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.49mH
Mechanical Q (Qms)8.1
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)0.46ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)13.8T·m
Diaphragm Mass Inc. Airload (Mms)27.7g
Maximum Linear Excursion (Xmax)6.17mm
Surface Area of Cone (Sd)223cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter8.18"
Baffle Cutout Diameter7.13"
Depth4.94"
Sealed Volume1.238ft³
Sealed F3215.8Hz
Vented Volume4.038ft³
Vented F3116.2Hz
