  • FaitalPRO 8HX150 8" Ferrite and Neodymium Professional Coaxial Driver 8 Ohm
NEW FaitalPRO 8HX150 8" Ferrite and Neodymium Professional Coaxial Driver 8 Ohm
FaitalPROPart # 294-1083
Model: 8HX150
The 8HX150 is an 8″ (200 mm) coaxial loudspeaker designed for professional sound systems that require compact yet full-range performance. It combines a dedicated low-frequency driver and high-frequency compression driver in a unified design to simplify system integration.
  • LF voice coil 2.56″ (65 mm) diameter with aluminum winding on fiberglass former
  • HF voice coil 1″ (25 mm) diameter with aluminum winding on Kapton former
  • Frequency range 75 Hz–4,000 Hz (LF) and 1,500 Hz–18,000 Hz (HF)
  • 90° nominal dispersion angle for the compression driver
  • Made in Italy
FaitalPRO 8HX240 8" Neodymium Professional Coaxial Driver 8 Ohm
Price: $489.00Part # 294-1084
See all items in Pro Coaxial Full-Range Speakers
NEW $282.00
We'll send you an email when FaitalPRO 8HX150 8" Ferrite and Neodymium Professional Coaxial Driver 8 Ohm is back in stock or available for preorder.
Order in the next 6 hr 52 min to ship today. Details
The 8HX150 efficiently covers both bass and high-frequency ranges in a single compact driver, thanks to its coaxial configuration. The low-frequency section handles up to 250 W AES with a sensitivity of 94 dB, while the high-frequency section delivers 15 W AES with a sensitivity of 104 dB for detailed upper frequencies. Both voice coils are built for durability and thermal performance, using aluminum windings on appropriate formers (fiberglass for LF and Kapton for HF). Its dual-driver bandwidth spans from 75 Hz up to 18,000 Hz, giving it wide-band capability for professional applications. With a shallow 4.40″ (111.7 mm) depth and a nominal 8″ (200 mm) format it is well suited for installation in compact enclosures. Its 90° dispersion pattern makes it a practical option for wide-coverage systems. The 8HX150 is an excellent choice for designers looking to implement full-range output from a single compact coaxial driver.
BrandFaitalPRO
Model8HX150
Part Number294-1083
UPC848864081885
Weight8.7
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response75 to 4000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2.56"
Resonant Frequency (Fs)76Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.51mH
Mechanical Q (Qms)9.5
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)0.46ft³
Mechanical Compliance of Suspension (Cms)0.2mm/N
BL Product (BL)11.6T·m
Diaphragm Mass Inc. Airload (Mms)22.3g
Maximum Linear Excursion (Xmax)4.92mm
Surface Area of Cone (Sd)217.2cm²
Voice Coil FormerFiberglass
Overall Outside Diameter8.18"
Baffle Cutout Diameter7.20"
Depth4.4"
Sealed Volume2.618ft³
Sealed F3170.3Hz
Vented Volume11.37ft³
Vented F377.29Hz
