Celestion TSQ2145 Ten Squared Series 21" Neodymium Subwoofer 8 Ohm
Using Celestion's cutting-edge “Ten Squared Technologies,” The TSQ2145 is unrivaled in terms of efficiency, longevity, durability, and quality. With an impressive 1,800W RMS power handling capacity and a lightweight neodymium magnet, this subwoofer is engineered for high-impact, professional-grade sound.
- Double-sided weatherproof cone for maximum durability
- High efficiency cooling for improved performance, endurance and longevity
- Lead out wires woven through suspension to reduce fatigue from regular use
- Proprietary tech for winding the voice coil gives Celestion drivers greater longevity
- Precision Tuned Venting (PTV) increases airflow to keep the driver significantly cooler than other leading brands
- Dual suspension with a layer of Polysiloxane in-between reduces stiffness
- Engineered and built in the United Kingdom
We'll send you an email when Celestion TSQ2145 Ten Squared Series 21" Neodymium Subwoofer 8 Ohm is back in stock or available for preorder.
