  • AtlasIED Atmosphere AZMP8 8-Zone Signal Processor with 1200 Watt Amplifier
AtlasIEDPart # 242-9677
Model: AZMP8
The Atlas AZMP8 is a cutting-edge 1200-watt, 4-zone audio processor/amplifier designed to be the central hub of an Atmosphere audio control system. Featuring advanced DSP, innovative algorithms, and ample power to distribute across zones, it provides tailored audio solutions for a wide range of environments. With an intuitive design and setup, the AZMP8 ensures seamless audio distribution across your Atmosphere network.
  • No app needed; control Atmosphere simply through a web browser using the intuitive interface
  • 1200W that can be distributed across zones in 5W increments at user discretion to low Z, 70V, and 100V speakers
  • Inbuilt DSP offers learning ambient noise sensing, virtual wall controllers, Tilter Filter, auto-gain, GPIO, and much more
  • Accommodates up to 16 wall-mounted controllers/sensors across four accessory ports
  • Combine and group rooms for flexible configuration of different audio zones
  • Programmable message player and bell scheduler to play pre-recorded messages on a configurable schedule
  • Wide variety of wall-mounted accessories available for control options
Your Price: $4,839.99
MSRP: $6,047.99
Save $1,208.00 (20%)
Out of Stock
We'll send you an email when AtlasIED Atmosphere AZMP8 8-Zone Signal Processor with 1200 Watt Amplifier is back in stock or available for preorder.
Dropship Order Item
The Atmosphere AZMP8 is a powered 1200 watt, eight zone audio processor that functions as the central hub of an Atmosphere audio control system. Its powerful DSP and advanced algorithm suite allow it to deliver customized audio solutions across a wide variety of spaces. A built in message player, virtual wall controllers, learning ambient noise sensing, Tilter Filter™, auto gain, GPIO, bell scheduler, room combine, and many additional features make the AZMP a true processing powerhouse.
The AZMP8 uses amplifier power sharing technology to maximize efficiency and prevent unnecessary system overdesign that is common with traditional amplifier power ratings. It provides a total of 1200 watts, and each output channel can be software assigned anywhere from 5 to 600 watts, allowing the system to be precisely tailored to the needs of each zone.
Engineered for full compatibility with all six Atmosphere wall plate accessories, the AZMP8 supports control, remote audio input, and ambient noise sensing. Up to sixteen plug and play accessories can be connected across four accessory ports, and a zone paging station may be added as needed. Each port reliably supports cable runs up to 1000 feet.
Programming is streamlined through a modern on board web interface that is optimized around common application workflows. Built on Progressive Web App technology, the control interface is device agnostic, highly responsive, and carefully designed to deliver an intuitive user experience without limiting customization. Built in Wi Fi provides convenient direct access for tablets and other control devices, alongside standard Ethernet connectivity.
Control modules are available for RTI, Crestron, Extron, and AMX.
Request Atmosphere Firmware Update Notifications
What is the Atmosphere Platform?
An Audio Processing and Control System with Intelligent Design, Superior Performance Digital Signal Processors, Amplifiers, and Accessories
Experience freedom from Complexity to create your
Product FlyerSystem ExamplesFirmware Updates
Atmosphere Accessories
Ambient Noise Sensor
Zone, Source, and Volume Wall Controller
Volume Controller
Remote Bluetooth Audio Input
Remote XLR Input
RCA/3.5mm Audio Input
Wall Controller
Wall Controller with Bluetooth Audio
Virtual Wall Controller QR Code Holder
Zone Paging Station
Rack Mount Kits for Up to Five or Three Wall Controllers
Recommended Speakers
AS Series Surface Mount Loudspeakers
Isoflare In-Ceiling Loudspeakers
AimLine Digitally Steerable Surface Mount Column Array Loudspeaker
BrandAtlasIED
ModelAZMP8
Part Number242-9677
UPC612079702237
Weight18.5
Power Output (RMS @ 70V)> 400W
Weight Range10 to 19 lbs.
