  • AtlasIED X-ANS Atmosphere Ambient Noise Sensor, White
AtlasIEDPart # 242-9662
Model: X-ANS
The Atlas Atmosphere X-ANS is a wall-mounted ambient noise sensor designed to enhance the functionality of Atmosphere AZM audio processors. By monitoring ambient noise levels, it enables automatic volume adjustments, ensuring consistent audio clarity across varying environments.
  • Compatible with AZMs for use with Ambient Noise Compensation and Loud Noise Detection
  • No audio content is returned to host processor (AZM)
  • Assign up to 4 X-ANS devices per zone
  • Use up to 8 X-ANS devices per AZM
  • Built to work with the Atmosphere platform
Your Price: $247.99
MSRP: $261.99
Save $14.00 (5%)
Out of Stock
We'll send you an email when AtlasIED X-ANS Atmosphere Ambient Noise Sensor, White is back in stock or available for preorder.
Dropship Order Item
The Atmosphere X-ANS is an ambient noise sensor designed for use with Ambient Noise Compensation (ANC) and Loud Noise Detection (LND) in the Atmosphere AZM. ANC automatically adjusts volume levels within a zone based on environmental noise, while LND monitors sound levels and triggers actions when noise exceeds set thresholds.
Engineered with advanced DSP algorithms, this technology enhances the installer and user experience by utilizing a patented data collection technique. Its patent-pending automatic ANC learns from user adjustments at specific noise levels, allowing the Atmosphere system to develop a unique adaptive curve for each space. This intelligent learning process creates an effortless and optimized environmental configuration.
The AZM supports up to four X-ANS sensors per zone, offering flexible coverage. For privacy-sensitive applications, the X-ANS transmits only sensor data, never audio.
Atmosphere accessories are intelligent, plug-and-play devices designed for ease of use and intuitive operation. The Atmosphere accessory bus supports up to eight devices per accessory port, efficiently transmitting audio and data over distances of up to 1,000 feet. Each accessory port can accommodate one audio input accessory.
What is the Atmosphere Platform?
An Audio Processing and Control System with Intelligent Design, Superior Performance Digital Signal Processors, Amplifiers, and Accessories
Experience freedom from Complexity to create your
Product FlyerSystem ExamplesFirmware Updates
Atmosphere Accessories
Zone, Source, and Volume Wall Controller
Volume Controller
Remote Bluetooth Audio Input
Remote XLR Input
RCA/3.5mm Audio Input
Wall Controller
Wall Controller with Bluetooth Audio
Virtual Wall Controller QR Code Holder
Zone Paging Station
Rack Mount Kits for Up to Five or Three Wall Controllers
Recommended Speakers
AS Series Surface Mount Loudspeakers
Isoflare In-Ceiling Loudspeakers
AimLine Digitally Steerable Surface Mount Column Array Loudspeaker
BrandAtlasIED
ModelX-ANS
Part Number242-9662
UPC612079700905
Weight1
