  • AtlasIED Atmosphere AZM4-D 4-Zone Audio Processor with Dante
AtlasIEDPart # 242-9600
Model: AZM4-D
The Atlas AZM4-D is a cutting-edge 4-zone audio processor designed to be the central hub of an Atmosphere audio control system. Featuring advanced DSP and innovative algorithms, it provides tailored audio solutions for a wide range of environments. With integrated Dante networked audio, the AZM4-D ensures seamless audio distribution across your Atmosphere network.
  • No app needed; control Atmosphere simply through a web browser using the intuitive interface
  • Multi-patented algorithms enable continued learning and adaptation to environmental changes
  • Inbuilt DSP offers learning ambient noise sensing, virtual wall controllers, Tilter Filter, auto-gain, GPIO, and much more
  • Accommodates up to 16 wall-mounted controllers/sensors across two accessory ports
  • Combine and group rooms for flexible configuration of different audio zones
  • Programmable message player and bell scheduler to play pre-recorded messages on a configurable schedule
  • Dante compatible to integrate seamlessly with other Dante-capable devices
Your Price: $2,314.99
MSRP: $2,436.99
Save $122.00 (5%)
Out of Stock
We'll send you an email when AtlasIED Atmosphere AZM4-D 4-Zone Audio Processor with Dante is back in stock or available for preorder.
Dropship Order Item
The Atmosphere AZM4-D is a 4-zone audio processor that serves as the core of an Atmosphere audio control system. Equipped with powerful DSP and advanced algorithms, it provides tailored solutions for diverse environments. Dante networked audio simplifies audio distribution to other Dante-enabled devices, while features such as a built-in message player, virtual wall controllers, learning ambient noise sensing, Tilter Filter auto-gain, GPIO, bell scheduling, and room combining make the AZM4-D a versatile processing powerhouse.
Designed for seamless integration, the AZM4-D is compatible with all Atmosphere wall plate accessories, supporting control, remote audio input, and ambient noise sensing. Up to 16 plug-and-play accessories can be connected across two accessory ports, with the option to add a zone paging station. Each port ensures reliable operation over distances of up to 1000 feet.
Programming is intuitive through an onboard web interface optimized for common use cases. Built on Progressive Web App technology, the control interface is device-agnostic, responsive, and user-friendly while maintaining design flexibility. In addition to Ethernet connectivity, built-in Wi-Fi enables tablets and other control devices to connect directly to the AZM4-D.
The Brooklyn 3 card used for Dante functionality supports up to 16x16 audio channels, though the AZM4-D is configured for 10x4 channels for Sources and Zones with onboard signal processing. Additional Dante outputs allow for seamless integration with other Dante-compatible devices, making it easy to route and distribute audio within the network.
Control modules available for RTI, Crestron, Extron, and AMX.
Request Atmosphere Firmware Update Notifications
What is the Atmosphere Platform?
An Audio Processing and Control System with Intelligent Design, Superior Performance Digital Signal Processors, Amplifiers, and Accessories
Experience freedom from Complexity to create your
Product FlyerSystem ExamplesFirmware Updates
Atmosphere Accessories
Ambient Noise Sensor
Zone, Source, and Volume Wall Controller
Volume Controller
Remote Bluetooth Audio Input
Remote XLR Input
RCA/3.5mm Audio Input
Wall Controller
Wall Controller with Bluetooth Audio
Virtual Wall Controller QR Code Holder
Zone Paging Station
Rack Mount Kits for Up to Five or Three Wall Controllers
Recommended Speakers
AS Series Surface Mount Loudspeakers
Isoflare In-Ceiling Loudspeakers
AimLine Digitally Steerable Surface Mount Column Array Loudspeaker
BrandAtlasIED
ModelAZM4-D
Part Number242-9600
UPC612079703111
Weight12.35
Weight Range< 10 lbs.
